Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
IotaYodi
QuoteIf you want to look more into Aether you have to consider the origin of matter.  Aether is the ZERO, the base; the origin of all matter.  Thus it can't have any properties of matter. It was and is there before the matter.  You can't compare aether to water - that is wrong.  It is not a fluid dynamic, it is not an energy, it does not have any properties.
To understand Aether - you have to compare and think of Aether; not matter.
Aether is not polarized; therefore it can't be measured or observed in any way known to us.
I agree somewhat.  I dont see the Aether as an entity unto itself. It may be a combination of forces with gamma ray bursts being at the top and interacting with the rest of the cosmos. Finding the source of these astronomically intense  energy bursts might shed some light on the nature of the aether.
What I know I know!
Its what I don't know that's a problem!
jbignes5
I agree with you aramaz on most of your points. 3 can and will work if you understand the base of the triangle. It is that sole part that can make any shape in the universe. Heck it is even how we make computer graphics that look so real.
And I hate to burst your bubble(ahaha little pun) but Water is the Aether. It is just condensed. The Aether is where water gets it's properties and since everything shows a fractal nature then water must be the key. It is the sole thing besides salt they we must have to live. Salt being the other because it is just another form of the Aether in solid form. Meaning that instead of it being made up of particles of gas it has structure to it or stiff matter.
What prevents the merging is not resistance but Surface tension. It is the boundry between two specific densities. The Aether though would have the exact same properties as water because it is so finely crushed that is resembles a fluid. But if we zoomed way in we would see that the smooth appearance has order and symmetry and complete roughness. Although the parts never touch because of the vibration of the medium in which that floats. This process goes on and on.. The more you look deeper the further it goes. That is the fractal nature we live in. It is evident in anything you look at. You just have to look at it with open eyes.
When close to a great source of charges it's density is super concentrated. When it is in space it becomes fluffy or extremely less dense. This is the reason we have an atmosphere and it explains the layers in our atmosphere perfectly. It also shows how matter organizes this Aetheric energy and draws energy from the Aether by slowing the Aether down. When matter's density is very high you have less Aether and more inertia. Meaning that inside our planet is a huge potential. This is evident by all the heat and expansion of our matter we live on. and in the case of Blackholes they get all that energy by being made of the very medium it floats in. It is the perfect conduit for the vibration all around it but it has direction and can bridge the gap of the Aether in huge lengths. All the matter that goes into the Blackhole is used for growth of that conduit and hence can bridge an even longer gap as it grows. Unfortunately this means that eventually Blackholes will get too big and might even break itself like it did in the beginning of our space. Who knows there could be miniature Universes inside all blackholes that reach a certain size in our space.
The Aether as I have stated is the background to matter. It is a component of matter as well. and it reacts to the Vibrations of the Aether. It is the reason for all forces(flows) we see today. Gravity and magnetism can be completely explained by the Aether and it's affect on matter as it channels the vibration of the plane we exist on. It is the whole reason why we have planes in the Universe and even our own solar system. Are there places in the universe that don't have the Aether. Well simply put yes because the Aether is a conductor of the vibrations of our container. Does it have connections to the rest of the Universe, absolutely or else we couldn't see beyond our own Galaxy. is it a straight line sight. I highly doubt it. Do we think we are seeing a straight line, absolutely and it is the whole reason things look black in outer space.
One experiment that brings this to light is the seemingly random charges that appear then disappear in outer space. they are not appearing and disappearing in a sense. What they are doing is traveling on a conduit and happen to be caught in the detector because the detector can not go fast enough to see it move in real time. So it appears to be appearing and disappearing. This process can be seen in this very simple experiment. Take a fan and put it in front of your TV at night. Now the fan doesn't look like it is going so fast but yet it is. This is the same effect we see in those experiments. It just means we can not detect the charges fast enough with our detector to tell the true path it follows. We only get glimpses of it as it passes the detector. Little blips as it is caught in it's path. It's true speed is the ultimate this network can go and that is way faster then we are capable of detecting.
If you get one thing out of the experiments I showed you from the 10k frames a second videos I would hope that it would be that you understand we as an observer are limited to our ability to see such minute changes in our space. We can't see the results because our own devices are limited to the devices sampling rate. We all to often say I won't believe it till I see it with my own eyes but I tell you you nor I would ever be able to see what we seek and then will never believe the concept because we can't loose that axiom we live by.
This I think is why I can see this process. Because I let myself look inwards to the Aether I contain. I know it is there and real and I can accurately describe it because my own Aether is giving me the information. I then look outwards to see the effects of the Aether all around me and I see it plain as day. Not with my eyes but with my own Aether I can sample the proof and see it's affect on matter. I can see the signs and not wonder why the natural processes have this pattern. I have made the connection that our ancients made before they had Technology that was invented. They simply copied what they saw in their Aether and proofed it by looking for the signs all around them. When they did this they truely understood their place in nature and lived without harming their environment. Simply because they understood the processes behind it all.
Of course some associated it with "God" and to tell you the truth as much as a Galaxy looks like bath scum going down the drain it would be crazy of me to deny that, that much energy would not have an intelligence about itself and the contents of itself. Seeing that connections are made over vast distances in our Universe we have to admit that in some way there is a "God" like intelligence out there made up of all the matter, conductors and energy that the Universe contains.
We sometimes mistakenly think we are the top of the food chain till something comes along that is much bigger then we think we are. Most of us are vain and egotistical in thinking we know the absolute truth and yet we know very little of the Universe and all it contains, even today we are finding new things that boggle our minds. Would this be any different?
Please understand I am not trying to argue with you. I'm trying to show you that we don't and couldn't know the truth even if we are swimming it. Heck we are made out of the very essence of the Aether and yet we have been taught to ignore our inner voice(Aether). It is screaming at us to change our ways and nothing will change till we change our views of us, our Solar system, our Universe. You might even say that certain beliefs in our history were very close to the absolute truth. In most of those believe internal searching for the secret was the key to enlightenment because the answer is within us and all around us. But since we have been programmed to not believe in our true instincts we ignore the facts our minds are showing us.
It is being proofed as we speak that we are all connected. That events can be foretold because we can access this information. Not in time but in the Aether. All events would have ripples much like the ripples we see in water as a drop hits the surface of the water. It goes all ways through time because time is but an oscillation of the Aether and matter allows time to be a constant because it slows the Aether the closer you get to the center of matter. Matter is the true resistance of the Universe because on our scale matter has mass and inertia and it also contains the Aether which is how it can effect the flow of the Aether as a reaction and it is bidirectional as well.
IotaYodi
Quotebut Water is the Aether. It is just condensed. The Aether is where water gets it's properties
That didnt make sense.
If the Aether is water then the Aether would be hydrogen oxide.
What I know I know!
jbignes5
Quote from: IotaYodi on August 02, 2011, 12:52:55 PM
Hmmm. So what is in between the molecules then? Obviously there is something there else everything would compress to the ultimate density? Which water is very compressible. What is that force that is holding matter from touching each other and melding together then springing back after the compressing?
The Aether is very much smaller then the oxygen or even the hydrogen is. It is that space in between the matter That we are talking about. In that space their seems to be a springy like connection that conducts and passes charges even while in the fluid forms of water.
If you say nothing then you have no idea about the scale at which I'm talking about and nothing about matter as well. On the smallest scales that we can see matter is suspended apart from each other. It is not because of some imaginary forces that we know nothing about. It is the connections that gives atoms it's ability to transmit energy or charges with.
Lets see what I am talking about:
http://www.blog.thesietch.org/2008/01/29/wana-see-what-gold-atoms-look-like/
This is the closest we can see atoms atm. Maybe there is better ones now, just that I can not find them or they have not been released yet.
When I say condensed Aether I mean that is not connected to the web or network and has the ambient charge level of the environment. Although it is connected to it's own network I believe that in the case of water the surface effect is a small break in this environmental network because of a severe density change of that network. In other works the network comes to a bottleneck and has limited connection to the environment network. The network is made up of the Aether conductors and is displaced by the atoms of matter or held in place. When matters density changes from water to the air there is a severe density change in the network between the air and water. So water would have tons more conductors in between it's matter then say air would. Hence the surface effect. This goes for anything that changes density.
IotaYodi
QuoteHmmm. So what is in between the molecules then?
Its not water.
What I know I know!
