SchubertReijiMaigo
Look like some bad news:  :-[ according my red (power curve) Current*Voltage...
Look like my version is not OU anymore... But rather an energy destroyer...  :o :o
Let's me explain,  at the input side PF is nearly 1 and the output is 1, but if you look carefully the two curve look like it need 2.5 time energy   :o :o to power a load, ie for one Watt at secondary you need 2.5 Watts (not VA)...
Question at 1 Yen here: What I have missed here !? It's crazy...  ???
How to turn in OU state !? (Adding turns, because my turn ratio is under one so for any trun ratio above 1 it switch in OU state !? Crazy)
Or the current at secondary is not measurable by conventional meter (Cold or Radiant current) I think I become mad here...
First Graph is INPUT and second OUPUT:
Mavendex
you changed your turns ratio to what?
SchubertReijiMaigo
It's the same as the download section, 156/117, Yeah it's crazy this the exact same version,  input is 12 V 50Hz... I calibrated the scope used the same shunt (a telephone wire) for current measurement, same scales, etc,etc make several measure but not I find this curious result... I think it's due to the turn ratio less than one... If I remember correctly I 'am the one with turn ratio under one...
Hmm I think it's time to ad turns at secondary...
Mavendex
I read that wrong sorry, That is interesting with conventional measuring that it would look like it isn't working but your output is different than what the scope is saying.
How deep does the rabbit hole go...
SchubertReijiMaigo
This is why I think about unconventional current like Radiant-Cold current. Many inventors and "Legend" tell that cold current cannot be measured by conventional meter but those current perform work like any other conventional current. Believe me, I 'am highly disturbed here, because normally nothing can trick an oscilloscope look like a fox prank for me  :D !!!
