Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 123 Guests are viewing this topic.
ronotte
Hi wattsup,
Quote from: wattsup on May 12, 2012, 01:13:34 PM
The question I have is should I simply use your original circuit diagram and just replace the IRF7307 with the IRF640/IRF9540 and run it like that.
Well, I suggest it indeed  :)
...just a note: before going to 24V try the safer 12V on final switch
Roberto
yfree
@All
There is an interesting update in PJKBook on the Kapanadze coil on page 3-107:
http://free-energy-info.co.uk/Chapter3.pdf
"The main secret of the Kapanadze coil is the conductive ring placed within the coil.  This is in contradiction to standard thinking; a closed conductive ring in a coil would normally create a wasteful shunt rather than be a source of energy. It is hard to believe that this piece of physics has been known at least since Meyer's experiments (around 1975) but it is speculated that Tesla and later Hubbard knew this as well."
jbignes5
Yeah it seems to me this process is superior to anything around. It sets up a perfect way of reflection compression in the electric fields. They need to be correctly wound to + and - flows (cw, ccw winds). Once that is correct you will be able to borrow as many lines as you would need. More lines= more power pressure in the bifilar wind. You could think about the flows being in and out simultaneously but in one direction. These lines cut through the heavy copper and alternately draw positive and negative energy in layers this increases the flow of current because they are attracting twords each other loosely.
The excitation fields are very complex surfaces and the lines supporting that surface has very little give. It seems to me that polarity does in fact change the direction of the flow. Either left or right so something in the shape of the conductor has to be working with this. Ether the crystals are slightly skewed to the left or right hand way. Crystal growth also shows this process but it doesn't explain why really. I hgavent research crystals enough yet to know but yes it has a slope to it.
Resistance of the drive unit Capacitor and associated wiring up to and including the coil must be kept very cool. Paralleling nano conductors would be the easiest way to lower the resistance with coatings being another. Paralleling circuits would also lower the resistance to near nil levels. Especially in space *wink*. This will enhance the speed of the device as well allowing for sub micro models with great power capabilities. Many many units could stack and create enormous flows in parallel current.
forest
Quote from: yfree on May 12, 2012, 02:38:59 PM
@All
;D ;D ;D
Don Smith has taken it from there....but you must know that with great knowlege goes great responsibility
