Lowest voltage where spark occur?
Started by Neo-X, July 10, 2012, 03:47:31 AM
Neo-X
Hi to all overunity builders. I was thinking to build a low power, low voltage teslacoil (cause im afraid of high voltage) using voltage multiplier circuit thus eliminating bulky transformer but i dont know what is the minimum voltage where spark occurs? Sorry for my bad english im not really native english speaking.
neptune
The lowest voltage at which a spark occurs depends, among other things, on the width if the spark gap. You could probably get a spark at 50 volts or lower with a very small gap.
Neo-X
Thanks for reply.. I tried 220volt from the mains and when i put the terminal as close as posible it didnt get a spark. So that means spark occur more than 220volts.
Neo-X
1000volt is a lethal.. Maybe i should use a gas which has lower dielectric breakdown so i can use the 220volts from mains.
Neo-X
