High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
kokomoj0
Quote from: IronHead on June 05, 2007, 09:22:40 PM
So far I know of 2 people in the world that have  figured a working Joe cell based on pure phenomenology . 2 out of hundreds that have  build these thing step by step. It is a long and endless battle it seems.
i like the concept of the joe cell but it seems like there is a lot of voodoo engineering attached to it...
Personally i am a fan of the brute force method, especially if it is possible to create a small positive pressure to the engine manifold which of course would act and perform like a turbo charger!  woohoo!
IronHead
I can tell you this . That you don't see real production till that bad boy is under vacuum . It will supprize the hell out of you. And vacuum is key when doing a full on HHO car , You need a mechanical vacuum pump in this case but thats the easy part. But don't look at the outrageous for now . Keep you build set on a fuel enhancer and mod from there.
Don't disappoint yourself before you get started by setting very high goals.
Here again this tread is to learn these things and link them together in the long run
Decrease your wants and you will be a happier person to build your needs.
IronHead
Moab
Quote from: IronHead on June 05, 2007, 09:32:35 PM
That sucks. we need a vacuum pump too? Just kidding. so whats next?
IronHead
Oh you need a lot of stuff if you want the choo choo to chug up the hill on water.
Don't be a stranger Moab , post!
Next start slamming HV to that cell  I want to see what you guys come up with. And forget about the heat. Heat is an accuse Slam that cell with volts /amps  let see what happens.. If you got 50 amps  put it on there ! Wear a respirator/eye protection  in this case with/without KOH in the cell and vent that stuff  until we close it up. You are going to get alot of caustic vapor. Keep your face outa the cell!! Start burning some HHO
Some of you guys have built to spec if you have  try taking out every other plate in the neutrals at HV. WITH THE POWER OFF:) If you have not built to spec  well than you can't do this part can you. If you hit 200 volts take out all the nutrals  lets see whats going on.
You will be building onto this cell soon so be ready  you don't have the bottom ,upper chamber  or top even built yet  nor do you have the water injection  chamber built. You have time
All new comers and and you guys that just got here from YouTube start on page 14
IronHead
magnetar
Quote from: Moab on June 05, 2007, 09:42:26 PM
You can get plenty of vacuum from the engine.  :)
You will probably increase the amount of gas produced  because the pressure is reduced.  Todays radiator systems have some extra pressure in them to keep the coolant from boiling.  The opposite is also true.  Reducing pressure allows the HHO gas to exit the water quicker which probably lets the electrolysis produce more to replace what is taken out of the water.
