A Kapanadze generator replication - Febuary 2013
Started by tika, February 20, 2013, 03:55:50 AM
totoalas
Quote from: tika on March 04, 2013, 07:21:12 PM
All the builds I've seen use spark gaps in the mm range.  A spark will form at between 1 and 2kV per mm of gap depending on air humidity.  SR193 was talking about a minimum of 3kV supply to start seeing see OU effects. Start low and go up, 3 inches sparks will make for a quite unruly circuit, when using a spark gap in series with the load, and working around it would be hazardous at best if not downright impossible when powered. It will also make placing other components such as diodes and caps very difficult, as you would need to drown them in epoxy, or mineral oil.
m:o)
Just found the yt channel comment of RimstarOrg   High Power mains Powered Ignition Coil Driver circuit  YT   lokeycmos   check this out   maybe you can replace the ignition coils with flyback    lol
verpies
Quote from: Grumage on March 04, 2013, 01:26:39 PM
Should there be a Copper ring between the Ferrite sets? The questions are endless :-\
IMO the copper (or brass) ring is essential.
Also, the greater the diameter of this ring and "ferrite sets", the better the device operates.
tika
Quote from: totoalas on March 04, 2013, 07:57:04 PM
That's interesting, but I don't see where this relates to Kapanadze's devices.
m:o)
tika
Quote from: totoalas on March 04, 2013, 10:41:44 PM
http://www.youtube.com/watch?v=B6hVasVR7AI&list=PLC7684829E98CAD74&feature=player_embedded
this guy used the spark from battery and earth to amplify in kapanadze
Yes, I know.  With an adequate HV supply, not one giving out a 3 inch spark.  Check his spark gap.
m:o)
