Rosemary Ainslie Circuit Demonstration, June 1 2013
Started by TinselKoala, June 01, 2013, 11:38:18 AM
profitis
@tinselkoala..calculations calcushmations,if she does my suggested experiment and if anybody can replicate it it removes ALL (not some) doubts about an overunity effect.in fact its the best way to publicly demo this thing of hers,an ordinary joe clearly undastands'this battery heat cup up but this battery heat cup up more,hosau kimjongsun'.its same things with rossi except here anybody can replicate.lets see if she,l do this tk.
profitis
she can even slow down the discharge of the shorted battery to the same discharge-rate of the circuit with a resistor in retrospect but still no problemo,its the best way.both bats must run flat flat.
Go see her then, she needs all the help she can get. You've got her email and forum links, right?
But remember that she uses six automotive or marine style batteries in series, each with 50 Amp-Hour capacity and around 400-600 amps of cold-cranking current output capability. Be sure to have someone video the event when you crowbar that battery stack and drop it in a cup of oil.
markdansie
@Profitis
I can nominate you as my special envoy for the purposes of validation....that solves the problem.
You can use the forum here as your technical support.
Go read the papers first and get her to explain why caps may not be used only batteries.
Mark
