The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Earl
Hi Brnbrade,
When the lamp is light up, is the 2-cell battery connected to the circuit?
Or is the battery only connected for a very short time to give a starting pulse and then disconnected?
Is this what you want the MOSFET switch for?
I can design a circuit for you, if I understand what you need.
Regards, Earl
jacob
Quote from: -[marco]- on July 01, 2007, 12:23:40 PM
The talk goes around the Farland Cook patents has been deliberatly changed.....
I do not know the reference source of where i heard it, but i am sure it was about these particulair coils.
Yes it was. And you heard it from me Marco. I made that claim a few times and the reason is simple. When you read the patent, it refers to elements in the drawing that are absent from the document. Therefore the conclusion that the drawing has been altered by simply erasing some of the circuit elements.
Jacob
Quote from: brnbrade on July 01, 2007, 10:23:12 PM
Draining which amps?
Yes, will test the behavior of the mosfet in circuit.
I will try in output the red wire of the device
Sorry, but I don?t really understand you here !
Which red wire do you mean ?
Where is a MOSFET or where do you want to have MOSFET in your circuit ?
I saw, that your email address is from Brazil,
so you speak probably Spanish language,right ?
Please post here in your Spanish language.
By the way, your email address is not right.
Email to your email address is returned with
"no user exists there"
Maybe then it is getting more clear.
Do you have connected the aluminium foil to any coil ?
If not, this might just only work as a shielding of magnet fields
via eddy currents.
Brnbrade, do you have a scope, so you can show us
the output waveform ?
Is it a sinewave with a few Khz ?
What are the 2 yellow cables that are coming from below the table ?
What do you feed into them ?
Please explain more.
Many thanks.
Quote from: btentzer on July 01, 2007, 11:59:23 PM
@ All
Please remember, with brnbrade's coils, His primary is of fine wire and is ON TOP of the larger wire, unlike you see in the patent.  ;)
And top coil primary, to bottom coil secondary.  Bottom coil primary to top coil secondary in mobius fashion.  The same on the other side.
Cheers,
Bruce
Hi Bruce,
are you in email contact with Brnbrade or where do you know this from ?
His email address he put into the forum over here bounces...
Please tell him to post in his mother native language over here.
Then he might be able to post more infos when he is here.
Many thanks.
abassign
Hi, Brnbrade
Excuse me if I have some doubts, the photo with the lighting lamp is very interesting, but the way of all the wires is not clear. Is it possible to have the same photo with all the wires and the condenser and the batteries ? Before beginning a check it is necessary to understand if there are not deceits.
Ciao
from Italy
