marathonman
Hanon;
very interesting concept and worth pursuing but copper foil is expensive and is not coated. one would have to coat manually and that would take some time unless someone knows where to get pre coated foil.???????
Doug1
Marathonman
MWS Wire Industries
31200 Cedar Valley Drive
Westlake Village Cal.
818 991 8553
Catalog= TechBook 082011 Pdf.
If you can find the catalog online there is information in there you didn't even know you wanted to know. They make stuff you haven't even dreamed of yet. I will try to upload the catalog as an attachment but I dont have very good luck with it. If it is there good if not it didn't work.
dieter
Thought I let you know, I modified my core to act like a BiTT. It definitly had a huge impact. eg. without it, I was able to get 200 mW from two secondaries in series, now this gives nothing at all anymore. I was however able to squeeze out a new record of 245 mW, compared to a max potential dissipation of 308 mW, but there are clues that the power factor was way under 1. When I attached the device directly to the supply, regardless of the tiny impedance of the primaries (dc resiststance about 14 ohm together), the supply remained cool and the wattmeter showed zero watts. Without the cap however, the dissipation went up to 7 watts. Without the core mod it usually  used to dissipate up to 20 Watts, way too much for the supply, so in that case it was getting very hot quickly.
This BiTT thing really seems to work. The temperature of a supply is a good indicator (when there is no oscilloscope) for effective dissipation, when the inductive load has only a few dc ohms...
Looks a bit taped and glued together, actually it is, but anywho...
marathonman
Quote from: Doug1 on April 06, 2014, 08:34:28 AM
Marathonman
MWS Wire Industries
818 991 8553
Doug;
I have a MWS catalog already in my possession but i didn't know whether the copper foil roll was coated or not. MWS is very expensive also and they don't sell partial rolls. i priced 18 awg wire at almost two thousand Dollars. OUCH !
Here is copper roll but i don't think it is coated so i will have to coat it myself.  http://basiccopper.com/10-mil-010-inch-.html
hanon
Dieter,
Thanks for sharing your results!! I don´t know if a capacitor unphases the intensity by 90º or it just unphases the voltaje. I am not sure of the answer. We are still far from the original design of Mr. Figuera.
About the document with the tape coil and like poles facing each other, after publishing that paper I realized that the induced field in fact oppose to the inducer field. I did a mistake and I applied the Fleming left hand rule (used for motors) and latter I learnt that I should had used Fleming right hand rule, which is the correct rule to be aplied for generators. So the induced filed actually is the contrary to the one I stated, and finally it really oppose to the inducer field.
If you think about the Buforn´s patent with all the electromangnets in a row, putting the group of 3 coils in series and one after the other, he said that with this configuration you could use the two poles of each electromagnet. This mean that with the basic group of 3 coils (electromagnet + induced + electromagnet) one pole of each electromagnet is not used. Thus, the configuration should have a pole in each electromagnet spoiled, and then, the only configuration which matches this situation is with the 3 cores forming a line. I don´t know but for any reason Buforn did not close the coil arrangement forming a perfect toroid. For any reason he kept it open in it sides. Tesla also used transformers with open magnetic paths (louse coupling). Maybe an open magnetic circuit is the way to tap energy from the surroundings. I don´t know. Just thinking loudly.
