Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
jonfrommanahawkin1
Dear friend ,
Galvonic is an effect of science. its caused by a electron difference in the atoms of the anode and cathode. Galconic corrosion will happen regardless if the Cell (tics)(for some reason I can't delet that) dry or wet the corrosion will take place. Its just a matter of time
As a cell's electrodes move up the galvonic scale in nobility they will corrode less and less and as a catch they have less power .
Its just a matter of money per cell and what combination will give you the best "bang for you buck "
All the best
Jon
PS great work!!!!
jonfrommanahawkin1
Pps both words are galvonic this site gets so many viewers my fisher price PC can't keep up lol
All the best
Jon
jbignes5
That cell I show above and ZERO galvanic response even though it has a lot of liquid in it. This was because I treated the aluminum with a borax coating. The process was this. I heated the aluminum up to quite a hot level. Then I sprayed on a borax solution which once it hit the aluminum puffed up like foam. Once the whole thing was coated I placed the aluminum Wire coil in the oven and baked the coating on for 1/2 to 1 hour till it turned golden brown. I then let it cool for an hour and inserted it into the glass jar. I proceeded to add more borax epsom salts, alum, and mortons salt substitute (potassium). and boiled the whole jar in a pan. When this heated up the mixture it started to combine all the ingredients. Once the solution was clear I took it out of the water bath and placed it on a board that I use for chopping. After that I inserted the graphite lead into the center and used a clothespin to hold the center electrode in place. The measurement was done after it had cooled and was starting to crystallize I measured the voltage of the cell.
There was zero Galvanic response in the cell. Both the Aluminum and graphite showed ZERO effects. The aluminum actually had crystals growing on them and it stayed shiny and pit free. After I had it running for 1 month or so. I decided to dissect the cell to have a closer inspection because the crystals grew to a point that they obscured everything inside of the jar. Everything looked as good as the day I put the cell together. So my take on this is that if you can find a way to protect the metal like I had found it means there will be little or no corrosion from galvanics.
Now comes the point really. All objects have a standing potential. If you devise a way to connect the two different materials using a crystalline material with Ordered water included in the crystal matrix then it will transfer energy without galvanics. The crystal material is the connection and we all know crystals can conduct and oscillate as in radio engineering. I chose aluminum because when it oxidizes it protects itself with a crystal layer automatically. This crystal layer is an Oxide of aluminum and this oxide can be used as an conductive interface.
jonfrommanahawkin1
fascinating stuff man
I know exactly what your talking about as far as crystal and radio wave interaction but there is a way to test for that and diclude the galvonic energy generation effect and what you could do is sheald the cell from emf radio and other wave leanghts to see if the current will change
And I love the boarax coating I'm going to try that if you don't mind
All the best
jonfrommanahawkin1
PS
Or also if you want to build a new cell to test the radio wave effect you could try and use the same metals as the electrodes and negate the entire galvonic effect all together
(Just a thought )
Jon
