Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
MarkE
Quote from: Neo-X on May 08, 2014, 01:14:38 AM
Im still believe that all thane heins said was true. We will not know it untill we test it... Im finished cutting the center leg. I cut it one by one using metal scissors. The center leg width is 1/2 of the two adjacent leg. Next, i will make a bobin using a plastic bottle.
You should finish your experiments.  If nothing else you will learn some things.  You could also read up on magnetic amplifiers.  It may help you to better understand what you eventually see when you run your experiments.
Neo-X
Quote from: MarkE on May 08, 2014, 01:48:22 AM
Are you talking to MEG? Where can i read about magnetic amplifiers? If i failed in this thane heins replication i will turn my transformer into MEG. I will completely remove the center leg then i will replaced it by a magnet.
Jack Noskills
Neo-X
Quote from: Jack Noskills on May 08, 2014, 04:56:21 AM
See what you can do with an alternate path design, picture of it below:
http://www.overunity.com/7833/thane-heins-bi-toroid-transformer/msg297417/#msg297417
Good design but i have no more material to do what is in the  picture and im content on what im doing now because i like a much simpler design. :)
Neo-X
I think in this picture when the flux flow from white core to black core, eddy current will produce if using a laminated steel core.
