The Holographic Universe and Pi = 4 in Kinematics!
Started by gravityblock, May 06, 2014, 07:16:02 PM
MarkE
I see that your election is to rave.  If you are not the crackpot Miles Mathis, it seems you are intent to give him a run for his money to see who might be a bigger crackpot.
gravityblock
Quote from: MarkE on May 24, 2014, 02:26:15 AM
Another psychological projection.  It is you, who is the crackpot, and your lack of scientific rebuttals and your election to rave is evidence of this.  You are spamming this thread!  Please grow up and stop!
Gravock
gravityblock
Quote from: gravityblock on May 24, 2014, 01:55:44 AM
Quantum Transitional Speed of 1,094,000 m/s
G*Z:  9.80 m/s2 * 30,585,600 seconds = 299,792,458 (speed of light)
299,792,458 m/s  / 274 m/s2 (sun's gravitational acceleration at the surface) = 1,094,000 seconds (based on quantum transitional speed)
274 x 1094000 m/s = speed of light
1 / 3.14 = 0.318309
0.318309 * 1,094,000 m/s = 348,231 m/s (aether's linear velocity according to Ionnis Xydous)
3.14 * 348,422 m/s = 1,094,000 m/s
The aether's linear velocity is 861 times less than the speed of light or 1000 times the sound velocity in air.
Wavelength (860.48 meters) = velocity (speed of light) / frequency (348,422 Hz) <---------Quantum Transitional Velocity is hidden inside this equation.
860.48 meters / 274.8 = 3.14 meters
I will continue this later when I have more time and tie everything together.  As you can see by this quick peak, the dimensionless numbers are fading away and changing into units/dimensions.  Wait for it......
Gravock
continuing....
860.48 meters / 1,094,000 seconds = 7.8654×10-4 m/s
1 km / 7.8654×10-4 m/s = 1.2714×106 seconds or 1,271,400 seconds
1,271,400 seconds * 0.86048 meters = 1,093404 meter seconds
Remember, 4 / 3.14 = 1.27 and we find this in the numbers above highlighted in bold.  Remember 4 - 3.14 = 0.86 and we also find this in the numbers highlighted above.
1,093,404 meter (distance) seconds (time) shows the relationship between the ratio of the distance and time around the circumference to the distance and time across the diameter.
In case you haven't noticed, all of these numbers are in perfect harmony with one another and have a direct relationship.  There is a video I would like to discuss with you, but before I present this video to you, it must be under the condition that you either accept Pi = 4 in a real circle with a time variable, or at least have an open mind.  I feel I have presented enough information in order for you to look further into this for yourself.  If you're still not partially convinced, then I will expand further on this and/or take another route.  Let's work together, and not against one another.
Gravock
gravityblock
gravityblock
The Ether (aether), by Miles Mathis
Below is a snapshot of the publication above.  Please note, it is possible to construct a rectilinear mathematical field underlying the curved field equations, giving us simplified calculations.  Once again, we see the term "rectilinear", just as the taxicab geometry and the squaring method is rectilinear.
Gravock
