Solid State "Synchro Coil".
Started by synchro1, March 31, 2014, 11:02:53 PM
synchro1
This coil generates "Magnet waves" with a sine wave signal. What effect does it's toroidal characteristics have on the coil's field.
                                      "Magnetic induction can occur in a zero curl magnetic vector potential field".
synchro1
The self resonating frequency of the thick wire bifilar primary should be tuned to permanent magnet field resonance. Jerry Bayles has determined that magnets reach resonant peaks at intervals factored by PI(3.14) and are irrational. Jerry oscillates Chiral satellite magnets at these rates.
Permanent magnet fields react differently to specific frequencies, like 7.8 hertz. There are higher reaction frequencies, but they are not linear or even proportional. They're a factor of the speed of the magnet wave which exceeds the constant C and includes the radical PI factor.
The question remains: What is the optimal operating frequency for this circuit? Sine wave hertz, self resonanting primay bifilar coil frequency, and the optimal resonating harmonic frequency of the permanent magnet field all need to match on the broadcast end.
The Primary needs to loop over the ends of the magnet for the diametric magnet to recieve the magnet wave on the perpendicular. I first thought we could wrap the the primary directly around the middle of the tube. This would project the "A" vector in the wrong direction in line with the field. The magnet needs to stand up in the center of the primary, so the magnet wave hits it at 90 degrees!
We're forced to select from only a small range of specific operating frequencies, maybe two or three! One is optimal!
We can "Egg Crate" these Coils and magnet receiver generators then circulate and collect the same sine wave oscillating current to power them at the cost of signal and resistive loss alone. This would make a free running kilowatts range generator.
synchro1
"Sweet claimed something on the order of 1:3,000,000 over-unity. The input power to his device was 10 VAC at 29 uamps (290mWatts) at 400 hertz. The output had been loaded to as high as 3,000 Watts".
Looks like Floyd may have alredy been there and done that! Floyd didn't have Neo Magnets, so he tried to soup the Barrium Ferrite up. We don't need to do that.
synchro1
Have a look at the toroid votexing around a single wire loop:
I think a series bifilar of two thick wire side to side, would generate a toroid field like a spiral where one wire ran around the outside of the other.
Lying a two wire speaker wire sideways one time around an large aire core would give the spiral toroid dimensions. Twisting the wire would give the coil a strong toroid vortex. I tested just these kinds of toroid spirals. A thick wire one would work fine, just twisted into a fairly large loop!
synchro1
I think the primary should be a spiral series bifilar toroid of two strands of thick 16 gauge insulated household wire. The strands could be twisted like a Spanish Knot tied around a plunger handle on one end, and a fence post on the other. Twist until a knot appears then trim and  connect the splice. It should resemble a phone cord. Maybe 4 or 5 inches in diameter. One loop and one loop only! This meets all the criterion. A low voltage hi amperage spiral series bifilar toroid, with a powerful "A" vector. A two minute job, and Voila, the perfect magnet wave generator coil!.
