Cold Electricity Breakthrough With Two Tank Transformers! Must Watch!
Started by Just..Sayin.., December 26, 2014, 01:00:34 PM
a.king21
It's people like Morin who give the free energy movement a bad name.
https://www.youtube.com/watch?v=29SRzaJBu48
All this replication is doing is generating mains voltage to light a bulb. No OU here.
His 2 transformer vid:
1: Voltage above 3,000 volts exists outside the wires. (Steinmetz - google and read)
2 High voltage  - 24,000 volts - will use the wire like a high speed train uses railway lines, except
there is no resistance to speak of, so the wires do not get hot.
3 High voltage produces a cool ion breeze. (ever heard of an ioniser??)
4 The cool ion breeze acts like a fan and cools the transformer.
5 The heaters are not calibrated - so we don't know how much power was consumed.
6 They appeal for investors. hmmm.  enough said?
7 Don't quote the scriptures at me - I may know them better than you for all you know.
This forum has nothing to do with religion.
frankidel
Ok, let's take a break here, if Morin measures his input ( voltage and current ) of the transformer with an analog meter and if he do the same with the output of his transformer going directly to the loads ( voltage and current ) you can just calculate the power ratio, out divided by input.  For a stand alone system, it's not important measuring the phase shift, vars, etc... as long as you can heat your home !  Remember the TK experiment with the 3 transformer, it's simple you will laugh.  So i'm asking him to make those measurements, show them that's it.  His generator can make 120 and 240, it's important, he measures the current in and out.  You dont have to make formulas and all that stuff, just that for me it's enough to tell us he can use a gasifier, his generator, transformer and the loads.
Yeah but just the fact that you have to ask him to make proper measurements is a red flag right there.  There is a "suspension of disbelief in deception" going on here.  It's amazing when you think about how many clips can generate such a buzz when the clips don't show proper measurements and many of them barely even mention it at all.
Then there is the mass hysteria for things like the QEG where it was "taken for granted" that it worked.
Watch out for that Kool-Aid.
a.king21
He asked for explanations about cold electricity and I gave them to him. How?  Because I've done the experiments.
I even have a voltmeter that can measure 30,000 volts which Morin says doesn't exist.
I like his enthusiasm, but it has to be based on reality.
He wanted answers so let us hope he begins to understand them, and discovers something real.
All he has to do is power his device using batteries and an electric motor-generator. Then feed the output to a second set of batteries, and swop.
That will tell him and us all he/we need(s) to know.
Hoppy
Quote from: a.king21 on December 28, 2014, 10:10:05 AM
Agreed! Fortunately, his videos are so way off reality, that those viewers with just an iota understanding of electrical principles will just laugh. In one of his silly videos, his mathematician friend suggested that his below zero beeping IR temperature reading was likely false but Morin is so off beam that he will probably never accept this.
