Rosch taking orders on OU Bouyancy device.
Started by ramset, April 26, 2015, 09:52:03 AM
Here you can see a chart which tells you, how much
mechanical output power such a paternoster system can
deliver depending on the height and the liters per minute pumped
into the floats...
At about 4.5 meters deepth you can see, that if around 300 liters air are delivered by a pump
it can not output more than  about 200 Watts mechanically at the upper gear axis at maximum...
If you pump only around 100 Liters air down to 4.5 Meters deepth,
you can only get around less than 100 Watts out...
So you see, that it is impossible by using normal physics formulas to extract 4.8 KWatts,
what they claim !
Here is the chart:
http://www.overunity.de/1797/rosch-auftriebskraftwerk-gaia-auftriebs-kraftwerk-wie-es-funktioniert/dlattach/attach/14592/image//
it was made by using all the current physics formulas by the engineer Dipl. Ing. Bruggmüller report calculations
by user uatu from the allmystery forum.
Here is the calculation of engineer Brugmueller:
http://gaia.ws1.eu/files/Wirkungsgrad_eines_Auftriebskraftwerks_pb.pdf
Here is an Excel Spreadsheet to calculate it all:
http://gaia.ws1.eu/files/berechnung-auftrieb.xls
Philip Hardcastle
I am concerned by the level of investors who I understand have bought into this, I have sent Stirling quite a few emails suggesting he should not give them any positive promotion, but Stirling is gung-ho on doing otherwise.
As to how the scam can be done, might I suggest that a close inspection of the float chambers might be a good idea, perhaps they hold highly compressed air, or a battery powered cylinder. Given the size of the floats it would be easy to hide 50% of the volume for the purpose of hidden compressed air storage.
Indeed if a hidden compressed air tank is within the float then it would be a trivial mechanism to let them bleed the highly compressed air continuously into the remainder of the float chamber,  after all it would be disguised with the operation of the visible compressed air injection at the bottom. The operating time would then be limited to the bleed rate of the hidden cylinders, probably 2 hours going by what Hartiberlin has noted.
If so there would be no need to have any hidden drive to the actual chain, and so no rattling.
Well no, the scam is probably done by a hidden cable going through these hollow wall hoider rods
to the tube and then directly into the generator, which is probably only idling
from the buoyancy and the hidden power cable is then directly wired to the generator output plugs
so that it seems, the generator is all doing the 4.8 KWatts output... but in reallity it is just idling
and does never see a load.
So the whole thing is just powered by the grid.
You could test this, if the main power for this building would
be shut down.
If then this KPP will still work I will appologize, but it is highly possible,
that then this KPP will also stop working...
I asked Mr. Reuter from Gaia to do this test to shut down the main power supply
of the whole building complex to see if it still works, but he got mad about me and just only called names...
Another proof that there is something fishy...they really don´t want to proof it,
that it really works...
ramset
so what does this mean?
within two hours of the first delivery the scam will be revealed [longest run time to date??] ,or perhaps sooner if they need to hook to the mains to get it working in the first place.
and these men all are known individuals with lives ,families and homes?
Do they not fear retribution from scammed persons as well as financial government penalties or prison sentences?
at what personal cost would they take such a risk??
that sounds even crazier in this day and age of instant worldwide media..
Thanks Grandma
