New reactionless motor from India
Started by pomodoro, August 15, 2015, 07:43:38 AM
tinman
Quote from: allcanadian on August 16, 2015, 10:42:21 PM
@Gravityblock
I once built PM motor which would not generate and I posted the plans for it here in the forums. It was interesting because it had a strong motor action however no matter how fast it was rotated it would not generate any voltage.
Now if we can build a motor which will not generate then why not a generator which will not motor?. In a motor the generator action generates a Cemf in opposition to the applied Emf limiting current. At which point we might ask what function does the motoring action play in a generator and what are the consequences of removing the motor function?.
AC
A shaded pole motor dose not generate,so just build the opposite to one of them,and you have a generator that will have no motor effect  :D
MarkE
Quote from: gravityblock on August 17, 2015, 05:23:49 AM
Call it whatever you want, but it doesn't change what it is.  Most people have adopted the analogy of a heat pump's COP to represent a system that is greater than unity.  I replaced COP > 1 with OU in my statement below.
MarkE and his minions can no longer use the argument that a system isn't OU if it can't be self-looped.  That argument is wrong based on a false assumption, as previously shown.
Gravock
Oh, I see you have propped up and slain another lovely straw man.
gravityblock
Quote from: MarkE on August 17, 2015, 08:39:54 AM
I have successfully refuted your original argument and position that a system isn't OU if it can't be self-looped.  I did not refute an argument that wasn't advanced by you, as you falsely assert.  You're false assertion that "I have propped up and slain another lovely straw man" is an appeal to emotion.
Gravock
MarkE
Quote from: gravityblock on August 17, 2015, 09:02:57 AM
Gravock
Then you have defeated a straw man of your own invention.  Be my guest:  Show where I allegedly made the argument you claim.
gravityblock
Quote from: MarkE on August 17, 2015, 09:46:27 AM
No, the straw man was your own invention based on a false assertion.  You continue to assert you didn't make an argument that was successfully refuted, without stating and clarifying your original argument and position.  You have done this so you can continue to muddy the waters.
Gravock
