ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
0 Members and 708 Guests are viewing this topic.
minnie
I remember Jack, he was one of the only people that I've come across that I
thought might be getting somewhere.
  His machining and construction was exemplary but at the end of the day
nothing positive seemed to come from it.
seychelles
Using the same idea we can change it into a MEG..
NOW THAT DOES NOT TAKE A LOT OF MACHINING .
Even my good GUM LEAVE EATING CREATURE can easily
wire this up in an afternoon after a hot cup of tea.
The reason i am not doing these great experiment i
am broke and unemployed at the moment..SO the winner
takes it all..AND I AM AT THE MERCY OF MY DARLING DICTATOR
WIFE WHO HAS EVEN ORDERED ME NOT TO VENTURE IN
MY OWN GARAGE TO RESEARCH OF THE HOLY GRAIL..GO
FIGURE IT IS HER WAY OR THE HIGHWAY I AM WORKING
ON THE HIGHWAY  PART..
seychelles
INDEGEN DO YOU REMEMBER THE STORY ABOUT THE GENIE
WHEN HE CAME OUT OF THE BOTTLE HE SAID IN A BIG LOUD
VOICE  YOUR WISH IS MY COMMAND. Just look at this circuit
and tell me where is the genie.. It of course the p magnet..The
flux of these two magnets is SHUNTED through the ferrite or iron
core  but when power is applied to the electromagnet KABANG THE
GENIE COMES OUT OF THE BOTTLE TO ACCOMPLISH YOUR WISH..
AND OF COURSE YOUR ARE NOT A MONKEY. GOD GIVEN IMAGINATION
IS YOUR MOST WONDERFUL GIFT PLEASE USE IT FROM THEN ON..
THANK YOU ..SOOORY FOR USING CAPS BUT I LIKE IT THAT WAY..
Tito L. Oracion
Quote from: tim energy on November 27, 2015, 07:23:45 AM
when the "scalar voltage" is so high, that the current starts to flow around the outside of the wire, 90 DEGREES TO IT'S NORMAL FLOW.
Quite often it will burn the coating right off the wire if the current can't find any where to go and the pulse is high enough. I can't do it electronically, but I can do it mechanically, and with only one pulse. NO resonance at all. Magnification of both amperage and voltage.  :-*
is this true TITO ??? ??? ??? ?
I don't know buddy. :o   ;D [size=78%] [/size] :D
why don't you share some scheme.
the floor is open to you.
Lets scruitinize it. :D
br549
Quote from: seychelles on November 27, 2015, 08:18:33 PM
seychelles:
This stuff is simular to Flynn's Parallel Path Technology. http://overunity.com/828/flynns-parallel-path/#.Vln9btKrTmU  I have worked through the proof of concept experiments and built several solid state devices. There is indeed a magnetic amplification of around 4 in Flynn's device. Like anything else, the trick is being able to figure out how to tap the excess energy. In the solid state devices I built (simulator to your drawing above, with out the rotor (Flynn's Parallel Path Concept) using laminations from standard (60 HZ) transformers and Neos, the big problem was Lenz's law. Once the core was magnetized one direction, I had to overcome It before magnetizing the core in the Opposite direction. Might be able to overcome some of that problem through the geometry of the core, and core material, maybe routing the push-back flux around the main path, maybe some fancy switch timing. The motor concept seems like it might be a little more straight forward as far a getting some excess energy (torque) out. I believe I have seen a calculation (online calculator) somewhere to convert between torque and horsepower. If you convert it to H.P. then to watts. In kind of a nutshell, The electronic version would be great, if you can beat Linz's Law,  otherwise the mechanical motor might show better results. I have been working   on a motor design in my spare time, but not there yet :-\.  Good luck in all of your Endeavors.
