The 'free energy' spark
Started by pomodoro, January 06, 2015, 02:30:01 PM
Magluvin
Quote from: jbignes5 on December 06, 2016, 11:43:04 PM
My point exactly Mags...
If you look at the diagram I put up earlier of the Tower, well that was from the notes going from Colorado to the Island.
It is very clear Tesla had other intentions for this device. The spark gap at the end of coil A which is an extra coil setup connecting to the very high capacitance top load. He used special single terminal tubes to disperse the High voltage back rush over the surface area of those single terminal capacitors. Kinda like a Leyden jar. This did two things. It gave the Tower something to collect the recoil from the spark gap at the ground connection. This charged the Top load immensely and attracted the plasma from the upper atmosphere down to the Tower. This allowed the top load to be charged to very high voltages because it was shorted to the ionosphere, which value is at +360k volts as we all know. Now it isn't a true shorted connection so it's value would be less but think about it. 200k volts or there about, going into the ground via the spark gap.
We know Tesla used the spark gap in his radiant energy patents (figure 1&2). This is no different if you know Tesla's methods or if you are schooled in the arts as Tesla would say.
The spark gap could be modified with a magnetic shunt and a special trigger point to get the process started. I assumed the spark gap was housed below ground to shield most things from the radiant energy blasts that Tesla's disruptive circuit causes.
At point G would be the normal Tesla discharge circuit as I drew out earlier. This allows one to convert the impulses into AC via a solenoid excitation via the impulses after point G discharges to ground (virtual as well).
Why exactly do you think they tore the Tower down? It wasn't because of them thinking the Germans would get it, oh no... It was because he hid this very fact from his financier Morgan that the tower was demolished.
If you read the text, well don't. It was only to get this past the Patent process. Refer to his Radiant harvesting techniques to piece this one together.
I think output of this device went to ground and radiated away from the ground. One huge capacitance just like the top loads on the Lodge coils (Tesla coils) of this day. He was broadcasting from the ground into the air as well and could harvest energy or intelligence at will and even using a virtual grounding system with it. The Tower was essentially free just like Niagara falls as and he hooked his system to the very wheel work of nature. The only cost would be building the device, everything else was free just like in Niagara Falls.
Hey Bigs
Im kinda not seeing the circuit you had shown as being what the pic shows. I dont see any indication that there is a spark gap in series with the G and C. I think its very possible the G and C LC is just a electrically isolated resonator. That is if he intended that the depiction holds more value than the description.
For my theory, and its just that, a theory, there would need to be a spark gap somewhere in the main coil circuit between the top of the tower to the ground, and where you point out, the connection area just above the ground plate looks like a good spot for it.
So as the top of the tower charges up, the spark to ground happens allowing current to flow through the main tower coil circuit causing a mag field impulse which stimulates the G and C LC. Then in return the LC induces the tower coil sending off the 'power' transmission, then repeat, depending on the freq of how often the spark can be generated. Kinda like you said about Niagara falls, this would use the charge in the atmosphere as the down flow of water.
If we can imagine the size of the tower, the C coil is made with a huge monster conductor in comparison, Super low ohm for little loss.
Maybe instead of having the spark gap in your circuit in series with the G and C cap and coil, there can be a coil collapse circuit dump to the cap to keep it going. If that collapse current is quick enough, the cap G would charge as the C coil being an impedance would allow the cap to charge possibly. If that is the way it is intended to be receiving input.  The missing spark gap in the G and C has me thinking otherwise.
Man, we need some farm land to build it. lol
Mags
Zeitmaschine
Quote from: Magluvin on December 06, 2016, 09:30:39 PM
Here I have a better resolution of the tower base circuit.
Quote from: Magluvin on December 07, 2016, 01:02:13 AM
Hey Sparks
Been a while. Wondered where you were.  Good to hear from ya. Looked back at your posts, its been a year.
Mags
Quote from: Magluvin on December 07, 2016, 01:36:26 AM
Hey Bigs
It seems this thread now is about one important thing: Don't reply to any post that mentions a concentric capacitor.
What's wrong with that concentric capacitor? Is it indeed the key to a working free electric energy device? So better not to call attention to it? Maybe a new thread should be created that summarizes this subject and hand over this one to chitchat Tesla's spark gaps.
iflewmyown
"Maybe a new thread should be created that summarizes this subject"
I would be happy to see a thread on the subject.
Garry
Zeitmaschine
Instead of writing all over again in a new thread I would prefer to save my time for doing some experiments. 8)
The Swiss Machine "Testatika"
That page says, source of the Testatika replication images unknown. But is it for real? If so, I can see a coil with two red wires inside a metallic cylinder which is connected most likely to (virtual) ground. Kapanadze's cylinder is also connected to ground. Kapanadze's output wire is orange.
sparks
  Hi Mags,
   Thought it interesting that using Tesla's highvoltage circuits could accelerate the radioactive decay of spent nuclear waste.  Just kind of intuitive is that the odds of k capture and subsequent transmutation of various isotopes would be greatly enhanced in an electronic avalanche.  The gamma and xrays could supply heat if captured in a suitable lattice while the waste is transmutated to stable elements.
  Good to see your still at it.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
