GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
.   .   The thing is, that if you so easily give up on this super simple free energy technology, then you will be not only be helping, but joining with Satan, and his evil forces, in helping keep this easy to build free energy technology from an energy hungry humanity. Then, if you truly think of this with a logic mind, and you are using AC electricity generators in the mini-pulleys, this just has to work
.   .   Yes, this free energy technology was given to the soon coming Tribulation Saints, which live through the 7 year peace treaty with Israel, the revived Roman Empire in Europe, and probably many other nations. I don't understand why you assume that these mini-pulleys will be under major torque, they only have free running AC motors/generators attached to them, which would only generate torque if they had major power being generated. They only need to generate one small blip of current, which is used to cank over your DC drive motor one single time,,, which is practically zero current, and even massive voltage times practically zero current, still equals practically zero power=costs practically zero torque.
.   .   You are listening to evil spirits to much, there is no torque problem
Quote from: Paul-R on May 25, 2017, 11:56:03 AM
... and gearboxes.
that_prophet
Quote from: Floor on May 25, 2017, 09:19:41 AM
@That_Prophet
Ezekial's wheel in a wheel, must have some significance, other
than that which you have understood it to have.
yes, I know that it has more to it than free energy,
because this was a UFO motor,
having anti-gravity properties
When one increases the rpm s of the generators (as in your drawings)
by using small pulleys on the generators and a large pulley on the
motor..... one also increases the energy needed to run the motor.
why do you think these mini-pulleys are so hard to rotate,
they are just attached to free running motors/generators,
these AC generators are running free
as P=IV, and the "I" is only one small spark, (practically zero)
so, since you only need practically zero current,
then "P"ower is equal to practically zero,
which means torque is practically zero
The generators will turn faster, but the motor is also more difficult to turn.
why would the motors be more difficult to turn, they still only have free running motors/generators attached,
This is Just like on a multi gear bicycle, when one has to push harder
on the pedals when in higher gears.
This may be hard for you to believe but,  that design has been tried many many
times before and does not produce extra energy.
but these mini-pulleys have no torque to go against them,
as they are just free running generators attached, with no resistance,
or very little resistance = divided by 1000 cycles = less than nothing
+ no,,, this design has not been tried before, except by the guy that built 3 working models, that says they work great
I have had many ideas that did not work out.  Disappointing as this can be,
one must move on / progress if one is to have any chance of finding a free
energy source.
Its not the devel's work, its just the way God and nature designed puleys.
       regards
                   floor
but this one does work,
and it is so simple that it MUST work,
You are using pulley technology to multiply rotations,
+ since AC electricity is created by rotations,
you can actually use pulleys to multiply AC electricity
you only pay to rotate a large 100 cm circumference pulley once = only on spark of DC
+ through the use of 10 mini-pulleys of one centimeter circumference,
you can get a return of 1000 cycles of AC electricity
that_prophet
I have had only one guy tell me that he built one, no, he told me that he built 3 different versions,
+ they all worked great,,,,
but he was worried about the rumors, of people that had actually built working free energy machines,
soon had bad things happen to them + their families,
so he did not want me to give out his name
Quote from: webby1 on May 26, 2017, 08:45:22 AM
...The real thing is, even when those that have built this tell you it does not work you simply carry on,, you ignore the information you do not want to hear,,,,,
that_prophet
you are not using logic, you are listening to satan and his evil demons,
telling you that torque is the problem
just think of 10 free running motors = no resistance but the viscosity of the lubricant
these would be easy to rotate, as they are just winding up massive voltage
which is exactly what you need, to crank over your large pulley the one single time
Quote from: webby1 on May 26, 2017, 02:01:29 PM
I could not get it to work,, BTDT,, I have tried variants of the same thing as well.
I do not believe that any person has built 3 that worked great,, you do realize how unbelievable it is that someone would not only build 1 but 3,,, why???
You have been informed of what the issue is that you choose to ignore,, the gearing up of RPM means the counter force created by that one little spark is geared up as well,, so 100:1 for RPM means 100:1 for the torque needed,, so that almost no current and almost no force quickly becomes really large really fast.
that_prophet
sorry to hear that,
I thought that it was simple + easy to build
as this technology was/is for the Tribulation Saints
who would not be able to buy much,
without taking the MARK,
which they would never take,
as it would condemn them to eternity in a place worse than hell
What is "BTDT"?
he probably built 3 to prove that it was easy enough to do,
or maybe 3  different voltages, like 1.5V + 9V + 12V
SORRY, but no, I have not been informed of any issues,
except the torque lies that the evil spirits have been lying to you about
these mini-pulleys + AC generators run freely
as they only need to generate one small spark of DC current,
in order to crank over your DC drive motor one single time
HERE IS A SIMILAR TYPE OF GEM
except the 4 medium size pulleys,
you would replace with 10 extremely small pulleys
+ 10 AC generators + 10 full wave bridge rectifiers
