GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
citfta
Several of us have already told you over and over again that the torque is not fictional.  IT IS VERY REAL.  But you continue to ignore us.  When you multiply speed you also multiply the torque.  This is just very basic high school level physics.  I am very sorry this seems to be beyond your comprehension level.  Please take the time to do some basic research about how generators and motors work.  Also do some basic research into torque versus speed physics.  These things are very simple and basic to understand.  And they prove without a shadow of a doubt what we have been telling you.  Most of the people that have been telling you your system can't work have actually worked with motors and generators and alternators.  We have seen the torque requirements first hand and have even measured those requirements.
Please stop posting on this and other forums about this idea.  And if you insist the rapture is going to be in two years then join a rapture forum and preach over there.  I do believe in the rapture but the Bible is very clear no one knows when that will be.
Respectfully,
Carroll
Low-Q
He is sailing his boat alone in the middle of the pacific ocean. Maybe he will be found stranded on one of the most remote island Henderson island in the pacific. His claims will fit well there among the other 18 tons of trash on that island.
I'll bet he will find both salvation and Jesus there too. And enough trash to build his device.
Vidar
Quote from: citfta on July 10, 2017, 04:31:04 PM
Respectfully,
Carroll
citfta
It  appears Aaron on the Energetic Forum has gotten tired of Joe posting the same thing over and over again over there also.  He has given Joe until the end of the week to post a video or pictures of a working device or he will be banned.  I just wish he would restrict his posting to only one thread here but he seems determined to continue to post all over the place here, even in other peoples threads.  To me that seems like enough to get him banned here also.  If he would keep his posts to just one thread I would not consider that enough cause to ask for him to be banned.
that_prophet
http://free-energy.yolasite.com/
This is such a super simple GEM=(Geographical Electricity Multiplication) pulley technology, that I hope it will clue you into just how powerful this spiritual warfare truly is, to be able to hide such an easy free energy technology. It only takes one small spark of DC current, to rotate a 100 cm circumference pulley one single rotation, giving you 100 cm of moving belt. Then you run this 100 cm of moving belt past 10 of the 1 cm circumference mini-pulleys, with free running AC generators attached, giving you 10X100=1000 cycles of AC electricity as a return or as an output. That's one minute bit of DC current in, giving you a return of 1000 cycles/units of AC electricity as an output. How can you not be multiplying your AC cycles of electricity, when through simple pulley mechanics, you are drastically multiplying your total # of cycles of AC electricity, by merely adding free running AC generators to your 10 mini-pulleys.
How can you not be multiplying you AC electricity, when you are only inputting one single spark/jolt of DC current, while you are gaining a return of 1000 cycles of AC electricity? These AC generators have practically no torque against them, as they are being used as free running motors/generators, with practically zero resistance to them. This is because even if they were being used to power your DC drive motor, they would only have to generate one small spark of DC current, which is practically zero power, and that would be divided by 1000 cycles of AC electricity, equaling practically zero torque, and that minuscule amount of power is being divided by 1000 units/cycles of AC electricity
You are using simple pulley mechanics to multiply your rotations by 1000, and by simply adding free running AC generators to your mini-pulleys, you are actually multiplying your AC electricity. Yes, that's right, you are using pulley mechanics to freely multiply your total # of rotations, + by simply adding 10 free running AC generators, you are actually multiplying your total amount of AC electricity. This is because your AC generators do not have to produce practically any power, so these generators have practically zero torque against them.
HOW SIMPLE MINDED HAS THESE EVIL SPIRITS MADE OUR HUMAN RACE, to not be able to see how simple this GEM AC electricity multiplication mechanism truly is. Where you only pay for one rotation of a large 100 cm circumference pulley, and through simple pulley mechanics, with free running AC generator, you are gain a return of 1000 cycles of AC electricity. HOW CAN YOU NOT GAIN THE MINISCULE AMOUNT OF DC ELECTRICITY, WHEN YOU HAVE 1000 CYCLES OF AC ELECTRICITY TO WORK WITH.
Please do not listen to the evil forces talk about torque being a problem, as great torque only comes from when you are generating large amounts of power. To make this GEM mechanism a self powered, you would only need to generate the smallest amount of power. You would only need to generate enough power to crank over your large pulley one single time, which is practically zero, and that minute amount gets divided by 1000 cycles of AC electricity. Do you see just how small amount of power that you must generate, to have this free energy mechanism self powering. With all of your 1000 cycles of AC electricity, you only need to generate one mere spark/jolt of DC current, and this super small amount of power is divided by 1000. So it's 1000th of one mere spark of DC current, so it is less than no torque at all.
COME ON YOU SERIOUSLY MISLED MANKIND, PLEASE SEE THROUGH THIS EVIL MYTH OF THERE BEING A TORQUE PROBLEM,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, PLEASE, WAKE UP PEOPLE + SEE THROUGH THESE LIES OF EVIL SPIRITS. SHAKE OFF THE MEDILING OF THESE EVIL SPIRITS, TRYING TO CONFUSE THE SIMPLICITY OF THIS GEM TECHNOLOGY. THIS IDEA CAME IN EZEKIEL 1:16 + IS DISCRIBING HOW A UFO MOTOR LOOKS WHILE RUNNING. SO THIS WILL NOT ONLY GIVE US THIS SUPER SIMPLE WAY OF MULTIPLYING FREE ELECTRICITY, BUT IT COULD HELP US DRAMATICALLY IN OUR FUTURE SPACE EXPLORATION WITH UFO FLIGHT TECHNOLOGY.
that_prophet
Yes,,, sure thing, penalize the guy who cannot produce a working model, not only because of his disability, but his place of living, that will not even allow him to have a single screwdriver, because one of his fellow neighbors might accidentally hurt him or herself on it.
This guy who is honestly trying to get this satanically blinded population to see how simple free energy is,,, by simply paying for one rotation of a DC motor with a 100 cm circumference pulley attached, would give you 100 cm of moving belt. If you ran this 100 cm of moving belt past 10 of the 1 cm circumference pulleys with free running AC generators attached, you would gain 10X100=1000 cycles of AC electricity.
THESE AC GENERATORS RUN FREE FROM MOST ALL TORQUE, BECAUSE TORQUE IS CAUSED BY POWER GENERATION + THIS ONLY NEEDS TO GENERATE ONE SINGLE SPARK OF DC CURRENT, TO ROTATE YOU 100 CM DRIVE PULLEY ONCE. (practically non-existent torque) So you have 1000 cycles of AC free energy to work with, in attempting to generate one mere speck of current, (just enough to rotate your drive motor one single time + guess what you have to start this work by, only 1000 cycles of AC electricity)
Use the minuscule amount of DC electricity that it takes to rotate one large pulley of 100 cm circumference, and through the LAWS OF PULLEYS, you can use 10 mini-pulleys of 1 cm circumference, to drastically multiply your total # of rotations by 1000 = 10X100
AND THESE AC GENERATORS DRAW ZERO TORQUE IN ROTATING, AS THEY ONLY NEED TO GENERATE ONE MERE SPARK OF DC CURRENT,,, AND THEY GET 1000 CYCLE TO DO IT WITH
THAT'S ONE SPARK OF CURRENT, DIVIDED BY THE 1000 ROTATIONS THAT YOU ARE GENERATING
<<<<<<<<<<<< THINK OF THESE GENERATORS/MOTORS AS RUNNING FREE >>>>>>>>>>>>>
As they get 1000 cycle of AC electricity, to only generate the miniscule amount of current that it uses to rotate only one single time
AC electricity is generated by rotations, so the more rotation = the more AC electric cycles that you are generating, off 10 absolutely free running AC generators. AND NO, THESE AC GENERATORS ARE NOT CAUSING ANY TORQUE, AS THEY HAVE PRACTICALLY ZERO POWER BEING GENERATED BY THEM. THINK OF THESE MOTORS AS COMPLETELY FREE RUNNING, AS THEY DO NOT NEED TO GENERATE ANY POWER. Remember these 1000 cycles of AC electricity, only have to generate the super small amount of electricity that it takes to rotate this DC drive motor one single time,,, only one spark, one short burst of current.
You are seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to turn one rotation of a large 100 cm circumference pulley, into 1000 rotations of 10 min-pulleys, + by simply adding 10 AC generators
Quote from: citfta on July 11, 2017, 04:54:38 PM
