170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
gotoluc
Quote from: seaad on March 21, 2018, 10:49:54 AM
Luc
Don't we have two neighbor coils on ?
First step, coil 1+2 then 2+3.
Perhaps you should widen the sec. core to 7 sections.
Just asking
Arne
français
Luc
N'avons-nous pas deux bobines voisines?
Première étape, bobine 1 + 2 puis 2 + 3.
Peut-être devriez-vous élargir la seconde. noyau à 7 sections.
Je ne faisais que demander
Not sure what you're trying to say Arne?
Pierre has confirmed there are 6 poles
So my 30 slots  /  6 poles =  5 coils or slots per pole
I cut my center core to magnetically couple with 5 coils or slot
We are not changing anything.
In Pierre's 36 slot he obviously has 6 coils or slots per pole and you can clearly see in the picture below his center core is exactly 6 slot wide.
Luc
français
Je ne suis pas sûr de ce que vous essayez de dire Arne?
Pierre a confirmé qu'il y a 6 pôles
Donc mes 30 fente / 6 pôles = 5 bobines ou fente par pôle
Je coupe mon noyau central pour coupler magnétiquement avec 5 bobines ou fente
Nous ne changeons rien.
Pierre a 36 fente, alors il a évidemment 6 bobines ou fentes par pôle et vous pouvez voir clairement dans l'image ci-dessous son noyau central est exactement 6 fentes de large.
seaad
Luc
""Not sure what you're trying to say Arne?
Pierre has confirmed there are 6 poles""
We still have 6 poles, but consisting of 2 coils side by side, displaces the magnetic field one step at a time while 1 coil is always on.
So to say make before breake.
See even Reply #373
Arne
listener191
Looking at the video with the microwave oven, the output current was similar to the input current with no load on the loop. When the MW was added the output went up to 11.5A but input remained the same indicating that it is load invariant. I suggest replacing the transformer with a switch mode power supply and remove the series resistor. The power supply will limit the super cap charge current. Then apply a 2 KW load and see if input current stays at 2A whilst maintaining 113-115V.
L192
seaad
First film at 13min 50sek --> input current falls to 1.6 - -1.5 A !! whem MWO is activated.
gotoluc
Quote from: seaad on March 21, 2018, 01:07:37 PM
Luc
See even Reply #373
Arne
français
"" Pas sûr de ce que vous essayez de dire Arne?
Pierre a confirmé qu'il y a 6 pôles ""
Nous avons toujours 6 pôles, mais constitué de 2 bobines côte à côte, déplace le champ magnétique un pas à la fois tandis que 1 bobine est toujours active.
Donc pour dire faire avant breake. Voir réponse # 373
Yes Arne, that is the reality and I guess when those two coils are on together at the point the pole flips there's going to be an interesting event to observe ;)
Could be what Pierre was seeing on his scope, the WWW?... we will see 8)
Luc
français
Oui Arne, c'est la réalité et je suppose que lorsque ces deux bobines sont allumées ensemble au moment où le pôle change de direction, il va y avoir un événement intéressant à observer ;)
Peut-être que c'est ce que Pierre voyait sur son scope les ondes WWW? ... nous verrons 8)
