listener191
Quote from: iflewmyown on March 24, 2018, 04:08:14 PM
In the U.S. many commercial microwaves consume about 1500 - 1600 watts.
Garry
français
Aux États-Unis, de nombreux micro-ondes commerciales consomment environ 1500 à 1600 watts.
Garry
Specification example of such an oven.
http://products.geappliances.com/appliance/gea-specs/JES1142SJ
L192
français
Exemple de spécification d'un tel four.
Cordialement
ARTMOSART
all,
je me demande si les moteur universel comme sur l'image ci dessous ne pourrait pas convenir pour ce type d'expérimentation ,il ont l'avantage d'être déjà bobiner comme il est indiquer ,en plus iles sont plus facile à trouver.pratiquement il suffit de piloter le rotor de façon à créer un champ tournant vers les bobine
du stator ,le rotor étant  maintenu physiquement fixe .les bobine du stator serviront de sortie .
en plus on trouve facilement des moteur à rotor de 36 poles.
pour ceux qui serais  intéresser  ,on peut aussi les piloter mécaniquement très facilement .
juste une idée ;)
all, I wonder if the universal motor as in the picture below could not be suitable for this type of experimentation, it have the advantage of being already wound as it is indicated, in addition they are easier to find. it is enough to control the rotor so as to create a field rotating towards the coil of the stator, the rotor being held physically fixed .the stator coil will serve as an output. in addition, it is easy to find 36-pole rotor motors. for those who would be interested, we can also drive mechanically very easily. just an idea
Mem
As I was falling asleep the other night I was imagining Pierre's DZ generator at works in a semiconscious state.
I saw clearly that  choppy sign wave, caused by the low speed relay contacts and everything else seemed to be just fine, like N & S pole orientations.
If you are planning to replicate this generator it might be a good idea use relays at first, and once you achieve similar success like Pierre, then you can switch to solid state devices to replace relays.
Being able to power the coils with IGBT's, Mosfet's or transistors etc. will produce a cleaner sign wave and give you adjustable frequency similar to VFD (Variable Frequency Drives)
The ultimate solution for DZ Generator power supply would be If some one can design a "Multi channel output regenerative VFD"
français
Alors que je m'endormais l'autre soir, j'imaginais le générateur DZ de Pierre à des œuvres dans un état semi-conscient.
J'ai vu clairement que l'onde de signe saccadée, causée par les contacts de relais à basse vitesse et tout le reste semblait être très bien, comme les orientations de pôle N & S.
Si vous envisagez de reproduire ce générateur, il peut être judicieux d'utiliser des relais au début, et une fois que vous avez obtenu un succès similaire à celui de Pierre, vous pouvez passer à des dispositifs à semi-conducteurs pour remplacer les relais.
Etre capable d'alimenter les bobines avec des IGBT, des Mosfet ou des transistors etc. produira une onde de signe plus propre et vous donnera une fréquence ajustable similaire à celle des VFD (Variable Frequency Drives)
La solution ultime pour l'alimentation du générateur DZ serait Si quelqu'un peut concevoir un «VFD régénératif à sortie multicanaux»
seaad
--> mosha
Good idea I'm also a fan of to find the "EFFECT".
But maybe You should take that motor idea to the parallel thread instead.
http://overunity.com/17609/170-watts-in-1600-watts-out-looped-very-impressive-build-and-video#.Wra2GC7wapo
I suspect that many here wants to replicate Pierres version.
Fr:
Bonne idée je suis aussi fan de trouver "l'EFFET".
Mais peut-être que vous devriez prendre cette idée de moteur au fil parallèle à la place.
Je soupçonne que beaucoup d'entre nous veulent répliquer la version de Pierres.
Best regards Arne
