GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
THIS IS HOW WE CAN FREELY MULTIPLY AC ELECTRICITY USING PULLEYS
A belt from1 rotation of a 100 cm circumference pulley, when ran past 10 mini-pulleys of 1 cm circumference, with AC generators attached, could gain 1000 cycles of AC electricity. http://free-energy.yolasite.com/
+ don't listen to the torque lies, as the only torque that is needed here, is the torque that it takes to crank over your drive motor one single time = practically zero current = zero power = zero torque
that_prophet
I HAVE DISCOVERED THE SECRET THAT TESLA WANTED TO GET OUT TO OUR WORLD = SIMPLICITY OF FREE AC ELECTRICITY MULTIPLICATION USING PULLEYS – Also found in our Holy Bible in Ezekiel 1:16 – where he describes the workings of a UFO motor as "wheels within wheels" .
. This https://www.youtube.com/watch?v=NxpoiCFKmPg is almost identical to the idea that I was shown in the early 2000's + soon put on the web @ http://free-energy.yolasite.com/ . Simple logic tells us that "yes we can" freely multiply AC electricity with pulleys, if we are only having to input a few bursts of AC or DC current,(however many phases it is) to gain the single rotation of a 100 cm circumference pulley. Then if we run this 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference with AC generators attached, then through simple pulley mechanics, we can easily gain 1000 cycles of free AC electricity. This way you must be multiplying your input power. You are using the God given abilities of pulleys to freely multiply the # of rotations, and by simply attaching AC generators, to freely multiply cycles of AC electricity.
. If this mechanism can easily generate the needed few pulses of AC or DC electricity that the drive motor needs to keep this free AC electricity multiplier running, then wouldn't that make this a perpetual motion power supply mechanism. It is hard to believe that the 1000 cycles of AC electricity output, cannot generate the small amount of energy needed to crank over your single drive motor the one single rotations. Not only is this simple, using only 2 motors, 2 pulleys and a belt free energy mechanism a perpetual motion machine, but it can even be a steady electricity producer. This free energy technology will be needed by the Saints after 2019.04, http://my2020vision.yolasite.com/ when the door will close for the signing of the infamous 7 year peace treaty. But this will be needed most after the mid-point of this treaty, when the Great Tribulation http://doorschristmustpassthrough.yolasite.com/
that_prophet
AC electricity is generated using rotations + the use of pulleys can be freely used to multiply the # of rotations,,,, SO WE CAN USE PULLEYS TO MULTIPLY AC ELECTRICITY. Don't listen to the torque lies, because the only power that this 1000 cycles of AC electricity needs to generate, is the small amount of power that it takes to crank over your drive motor one single time. Torque is only needed when you are generating power, and power is defined as voltage multiplied by current. Since the current needed is only a few short burst, (depending on how many phase the motor is), which is practically zero when you are talking about a steady current. Practically zero current when multiplied by even massive voltage, would still be equal to practically zero power, costing practically zero torque. Which means that their is no torque problem = that is a big phony lie that evil spirits tell you.
THINK OF IT THIS WAY = PURE SIMPLICITY. You only have to input one rotation of a 100 cm pulley + using a simple belt connected to 10 mini-pulleys of 1 cm circumference with AC generators attached = you can freely gain a return of 1000 cycles of AC electricity = 10 X 100 rotations.
HOW CAN THIS NOT BE A PERPETUAL POWER SUPPLY – or are you trying to tell me that with 1000 cycles of AC electricity. (notice that I did not state any voltages = because this free AC electricity generator can be any voltage)
that_prophet
My math is simple = This single rotation of a 100 cm circumference pulley, freely multiplies into 100 rotations of every 1 cm circumference mini-pulley that you choose to attach to the same belt. If you attach AC generators to these mini-pulleys-(you could add many) then you could gain 100 cycles of AC electricity, for every mini-pulley that you add. Now, don't you think that these 100 cycles of AC electricity could manage to gain the small amount of power that it takes to rotate the DC drive motor once,,, with a 100 cm circumference pulley attached = this is perpetual motion realized + even better, as you could tap AC or DC electricity off this set of perpetually running motors.
-(I wanted to find a way to help the Tribulation Saints survive the Great Tribulation) 2nd Door=2022/49
I found this technology from the description of how a UFO motor looks as it runs, in EZEKIEL 1:16)
https://www.facebook.com/groups/274842009339398/?ref=bookmarks
http://aliensandghosts.yolasite.com/
http://beliefstoliveby.yolasite.com/
that_prophet
Hello fellow inquisitive one, HIS BRIDE HAS LESS THAN 4 MONTHS TO LIVE
On this earth, before the Rapture takes us off this earth, + we go to the Wedding
The 1st thing that I want you to know, is the TRUTH about the RAPTURE
CHRISTIAN AGE ENDS before 2019.04 or JAN 14.57 = 1st DOOR closing
When He first showed me this free energy technology, I wanted to be sure,
that it came from good spirits + not evil spirits
I later found this tech in Ezekiel 1:16 speaks of a UFO motor as "wheels within wheels",
+ because of free multiplication of rotations, this is a self powering set of motors = FREE ENERGY
THIS GEM TECH IS SIMPLE LOGIC, THAT EVIL FORCES ARE HIDING .
Free energy can be generated using pulleys,
because pulleys can be used to freely multiply the # of rotations
+ since AC electricity is generated by rotations, then we can use pulleys to multiply AC electricity
WHY DOES NOBODY SEEM TO THINK ABOUT, or MENTION
THAT THE FIRST DOOR IS COMING TO A CLOSE ON 2019.04,
or JAN 14.57 = (COMING UP IN LESS THAN 4 MONTHS) This is +
not a prediction of the date that this will occur by, but this is the date
that this prophecy can no longer be fulfilled past this date. This is where
the "end of the world" miss-translation is found + should be translated
as "end of the age", as in "Christian age". This is a deadline, or when
the door closes on it still being able to fulfill the prophecy about
it happening within t within t were both the signing of 7 year peace treaty
with Israel + the pre-Trib Rapture MUST happen before this
first door closes. Please Google "doorschristmustpassthrough"
This is some very important NEWS to
share with this world. Although we are warned of that the "day +
hour knoweth no man", we are also assured that we would know
"when it was near, even at the doors". This first door will close on
2019.04 = DEADLINE for signing of infamous 7 year peace
treaty with Israel + the Pre-Trib Rapture.
Did you ever wonder how we could know
that it was near, if no one could know the day. It was
because we could know the generation, and all generations have an
end date. Well this end date could be the door, as in when the
door will close on it being able to fulfill the prophecy about
"this generation shall not pass". I know that there are a lot
of duration for a generation, but i figured that it was probably
the 51.6 solar year duration, as this was the same duration that
was used to accurately predict the rebirth of Israel.
We are told that there are 14 + 14 + 14
generations from Abraham to Jesus in (Mat 1:17)
14 + 14 + 14 = 42 generations
2,167 is the year for the Birth of Abraham.
http://www.stanford.edu/~meehan/donnelly/bibchron.html
http://www.israel-a-history-of.com/story-of-abraham.html
http://www.olive-tree.net/redemptiveplan/Chronological/Old%20Testament/overview%20I.htm
2,167 / 42 = 51.595
51.6 = duration of our end time generation
PROOF -(this was the same duration used
to predict the date of Israel's rebirth = to the exact day)
GOD'S SECOND CHANCE RULE, (sorry that I forget the book + verse)
= 10 times original duration = duration from when
prophecy was given + day Jesus entered the
temple=(prophecy fulfilled), then multiply # days by 10 = May 14th
948 = rebirth of Israel = 2nd chance for Israel to show this world Christ
(please read the novel called
"Armageddon", by Grant Jeffrey )
as this novel symptomatically went
through all of the fulfilled
prophecies in Scripture + displayed the
reality of every one being
fulfilled to the day = in the Holy
Bible KJV. This novel helped me
discover Scripture as TRUTH + I soon after became Born-Again
USING PULLEYS – Also found in our Holy Bible in Ezekiel 1:16 - where he describes the workings of a UFO motor as "wheels within wheels"
1st DOOR closing = 2019.04 - signing of 7 year peace treaty
+ 2nd = 2022.49 – Great Tribulation = most all evil is sent to earth
+ 3rd = 2025.94 – Jesus Christ sets His Feet on earth
http://possibletimingfortribulation.yolasite.com/
= FREE ENERGY IS POSSIBLE = http://freeenergy.yolasite.com/
It is as simple as the lesson that you
learned way back in preschool, where they showed you how a single
rotation of a larger pulley could be converted into many
rotations of a smaller pulley. Well, this can be a significant
thing, when talking about AC electricity, as more rotations can
mean a greater amount of cycles of AC electricity. So, in effect,
you can use pulleys to freely multiply the amount of AC
+electricity that you have.
Think of only paying for the single
rotation of a DC motor, (a few bursts of current) with a 100 cm
circumference pulley attached, rotating 1 to 10 mini-pulleys of 1 cm
circumference, attached to AC generators + giving you a return of 100
to 1000 cycles of AC electricity, (10 X 100 = 1000). + don't you
listen to the evil spirits, whispering that torque is a problem,,, =
because the only torque that you need to produce, with these 100 to
1000 rotations of AC generators, to make this GEM device a self
powered free energy system, of one DC motor + 1 to 10  AC generators,
is the minute amount of current that it takes to crank over your
single DC motor one single time = a few short bursts, which
equals practically nothing, when it comes to current. This is
because practically no current multiplied by even massive voltage,
still equals practically zero power – costing practically zero torque.
Q1
– IS THE RAPTURE SCRIPTURAL TRUTH = YES, there are many scriptural proofs
. (Rev 4:1)-",,, a door was opened in heaven,,, Come up hither,"
. (Mat 24:31)- ",,,send his angels,,, they shall gather together his elect"
. (Luk 21:36)= "Watch,,,and pray always,,, be accounted worthy to escape"
. (1 Thes 4:17)= ",,,remain shall be caught up,,, to meet the Lord in the air:"
. (Rev 3:10)= ",,,I also will keep thee from the hour of temptation,"
. (1Cor 15:52)= ",,,in the twinkling of an eye,,, and we shall be changed."
. (Tit 2:13)= "Looking for that blessed hope,"
AND the glorious appearing = (He comes twice)
Q2
– WHEN DID THIS GENERATION START = 1967.441,
. this final generation has already stared
. the day that the Jewish army took Jerusalem
. in the six day war of 1967 this final generation started
. which was a prophecy about Jerusalem = (holy city)
. so the generation could not have started before this time
Q3
– DO YOU BELIEVE IN SCRIPTURE
. well, Scripture assure us that there is a door/deadline
. as in, the day of the Lord MUST arrive before
. (Mat 24:34) "Verily I say unto you,
. This generation SHALL NOT PASS = (die)
. till all these things be fulfilled."
THIS IS THE 1st DOOR, WHICH WE ARE ALLOWED TO KNOW
"know that it is near, even at the doors" (Mat 24:33)
My Ministry websites:
http://biblefilescentral.yolasite.com/
