Bifilar pancake coil overunity experiment
Started by ayeaye, September 09, 2018, 09:42:32 AM
partzman
Quote from: Void on December 22, 2018, 01:44:04 PM
Hi Partzman. I don't know exactly what your circuit arrangement was when doing your measurements,
but, if I understand you correctly, measuring a COP of about 20+ one way and measure a COP
of about 2+ another way seems to indicate that something is quite wrong there somewhere.
Hi Void,
What do you propose is the source of the large differential in COP?  Which one is more accurate?
Pm
Void
Quote from: partzman on December 22, 2018, 02:23:29 PM
Hi Void,
Pm
Hi partzman. I am not sure, as I am not sure how you did your measurements.
Was your measurement method the same as what Itsu was doing in his last couple
of measurement tests? Did you have the isolation transformer at the input as well?
partzman
Quote from: Void on December 22, 2018, 02:46:30 PM
Same basic schematic as TK but no isolation transformer.
Pm
Void
Quote from: partzman on December 22, 2018, 03:51:43 PM
Pm
I see. I think you may well need the transformer at the input like Itsu is doing since the transmit pancake coil is
open circuit at one end, so very hard to measure the input power to it otherwise. That may be where you
are having a measurement issue.
tinman
OK,how easy is OU to achieve ?
Easy
First take your bifi coil.
Set up as circuit below--secondary open.
Crank FG up until more power is being returned to the FG by the bifi coil,than the FG is delivering. :D
First scope shot at 1Mhz
Second at 9Mhz-->OU  ::). I mean,the calculated power has gone negative   :D
Brad
