How does overunity 'suppression' work if everyone knows about it ?
Started by postingsite, November 16, 2018, 08:50:25 PM
A 3 capita household needs per annum 1350 KWh energy ( included storage losts) for warm water
------------------------ No electric solution : 1350 KWh / 1,5 savings through duche-head/ water-air mixer : 900 KWh p.a.
900 Kh / 1,5 DIP-tube, hot-cold water - mix battery : 600 KWh p.a.: 300 KWh summer 300 KWh winter
Solar collector1400 KWh solar radiation per sqm , 30% collector efficiency  ergo 1400 x 0,3 = 420 KWh;
  280 KWh summer 140 KWh winter ;  superconductive ink coating : 420 KWh summer 210 KWh winter;
  winter collector concentrator( mirror) : 420 KWh summer 315 KWh winter ;
Satisfaction point reached ! 600 KWh need / 735 KWh heat generation  with 1 sqm collector
Who needs more thermal energy, use more absorving area !Pump-free : thermo- syphon
Do it yourself devices, simple, low cost, low machinery.
Ultra- ecologists can optimize this by " showerloop"- concept ( google ! DIY-plan,relatively costly) use  ------------------------------------------------------ "Zero warm water heating"  is one step from the total "zero energy building"-program.The other is the "zero energy space heating/ cooling" and at last the " zero energy house appliances ".Zero space , f.e. expanded family: 80 sqm, atlantic coastal climate :  from 6000 KWh to 3000 KWh, coating, to 600 KWh, FIR-radiator, to 240 KWh, radiator-resonant circuit.
  240 KWh/80 sqm = 3 KWh electricity per sqm floor-area per annum heat, 3 KWh x PER 1,8= 5,4 KWh PE Solar
   Passive House energetic stanndart ( space heating) : up to 15 KWh PE p.a.-
  Satisfaction point reached : 5,4 KWh / 15 KWh PE ;  Solar Passive : Ireland : new building energetic minimum construction standart since 2018
   ----------------------------------------------------------240 KWh p.a. electricity by source : solar cell concentrator, concentrated wind force converter, water gravity wheel, magnetic force battery et cet.  -------------------------------------------------------------
house appliances ( permanent work: refridgerator  or periodically needed devices) 1,5 KWh electricity consume per day by " intelligent household" concept; Wattpeak controler;1,5 x365 = 547,5 KWh p.a.by source : solar cell concentrator, concentrated wind force converter, water gravity wheel, magnetic force battery et cet.  --------------------------------------------------------------Zero heating + Zero house appliance energy : a 250 Watt permanent working and battery/ capacitor bank charging device is for the "Zero energy Building" sufficient
Belfior
Quote from: postingsite on November 16, 2018, 08:50:25 PM
Just assuming  'self-powered-overunity-devices'  may actually function .
Everyone knows that 'self-powered-overunity-devices' exist, are easy to build, and have been around since approximately the late 1800's .
I'm one of the .001% of the population who did not know of their existence until I worked out how some them would work and posted it, some of these concepts had occurred to me a long time before the www-internet existed .
And yet almost everyone everywhere suppresses their existence .
What about times in the last 100 years when you'd think these devices would have been used, why weren't they .
Well if OU exists, then suppression exists. That is just how operational security works. If I want to keep my trillions, then I need to make sure that people don't pull energy out of thin air. A lot is riding on the money that the energy industry makes.
You fund institutions and when they get dependent on your money you just dictate what is acceptable research and make is taught in schools.
On Planet Earth is a permant energy producing 50Watt device in power per annum aequivalent with a 1 sqm- local 1400 KWh solar radiation and 30% efficiency- solar cell module panel !50 Watt x 8766 hours = 438,3 KWh
1400 KWh x 0,3 = 420 KWh + 70 KWh in winter 1 sqm mirror-foil = 490 KWh-------------------------------What can you do with 490 KWh per annum ?Mister Chalko from the mtbest- organisation ( no URL wished, no URL delivering !) recom(m)ends:0,8 KWh electric x 365 days = 292 KWh " intelligent use" from electric sources  !
The Monolithdomes- Institute, by example, shows a 112 sqm great dome constructed, U.S.A.- climate, and
a Wattpeak heat consume about 2400 Wp; this can become decreased by internal coating to 1200 Wp, by use from optimized heat pump or Infrared-heaterwe get an 120 KWh per annum electricity need. -------------------------------                                         292 KWh + 120 KWh = 412 KWh consume/ 490 KWh generating by
                                                         ONE SQUAREMETER SOLAR CELL MODUL PANEL--------------------------------    1sqm and 30% efficieny or 2 sqm  and 15% efficiency or 3 sqm and 10% efficiency  --------------------------------
all year around hot/warm water : electric free solarcollector
Nobody will get the "free energy device por gratia" , you will get "open source" -plans in detailed information,digital construction scheme
but you will ever have to spent money or other valuables worth to get the material, the tools for this device by your own and you will need qualified minimal skills and in functional generation of electric current, the Voltage/energetische Spannung/Tension is free around you and clearly also inside you: the earth is a capacitor, the human body is a capacitor.perpetuum mobile naturae, how defind by the Royal Academy of Sciences to Paris in the 18. century
I see everywhere so called " nationalism movement"-s,Abkanzelung, and complain Darwin and Galton research :EUGENIK= resource-battles worldwide; no intelligence, no crudness= no future1/3 of all employees in the G7 declares their job as Bull-Sh.-job, because they know that it is not existance-relevant; comparing 300 millons habitants ( nature balance ideal) and actually +-  8 billions habitants: 7,7 billions or 96,25% of all habitants are not NATURE-RELEVANT, by simple arithmetics.Numbers are so clear and pseudo-importance destructive !
PYTHAGORAS : DIE ZAHL IST HEILIG
Really " spassig" ( Pardon me, it is an URL)
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.sueddeutsche.de%2Fpolitik%2Fnationalismus-die-neue-weltformel-1.4270105
Karl Marx : Kommunistische(~ geral/general) Manifest( ~contract, volonte',constitution)
Henry Ford : "Godfather and Party-Bible constitutionalist " from the NSDAP, clearly anti-.......
                   GERMAN NSDAP-IDEOLOGY MADE IN USAhttps://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FDer_internationale_Jude
       Pro-Ford,Anti-Ford: Scheiss drauf, wir fahren fort !
                                                Quantum maths device : imaginability
                                                          cum putere to Computer
                                                          cum mutare to Commutator
                                                          cum parere to Comparator
                                   motere : motor  genere : generator formare : former
                                                              inter ~ trans ~ tele
            Physics Vocabularium is based by Latin-Expression and knowledge education and understanding.
1 year : 8766 hours : 525960 Minutes x 3000 RPM rotative device = 1577880000 RPM per annum
                                                 no load, quarter load, half load, full load
        friction factor ? bearings ultra-/ low
                                                electric coils: +- 100000 hours lifetime
                                                         Laplace " operator" device : modern " processor "
                                     3000 RPM ~ 50 Hertz swings/ cycles per second a 2 pulses frequencies
1 year : 8766 hours : 525960 Minutes :  31557600 seconds x 50 Hz frequencies device =
                       1577880000 Hz per annum by 3155760000 pulses frequencies per annum
Now : calculating with 1000 Hz= 1 KHz, 1000000 Hz= 1000 KHz= 1 MHz ....... Giga,Thera,Peta,Exa
                                      processor~ quantum-OU-device : lifetime-warranty ?
                                                           ballance-staff : really "Unruh"-ig
                                                          speech is silver - silence is gold
                        Laplace, pardon moi, Duque/Duke/Herzog de Laplace,royal, french
                        the inventor from the industrial micro-chip -idem- french,but simple citizen
clunkprocyon
People need money first and foremost. Most likely the ability to perform endless work is cheating as far as money is concerned.
