Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
                                                          Gray pop looper.
We need to disconnect the negative coil electrode, connect a diode and re-attach it to the positive pole of the battery. The capacitor is concealed behind the AA. The art of light gimmickry.
http://https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==APjJmp0UARgEXDSzpAyqMPiDvhg/content/parts/@.id==2.2/thumbnail?appId=YMailNorrin&downloadWhenThumbnailFails=true&pid=2.2
synchro1
Flash Mod Gray tube.
It would be easy to build a "Gray Tube" with the spark gap between the positive of the battery and the negative of the capacitor. Just get the screen around the gap and run the electrode to ground.
synchro1
Quote from: synchro1 on January 08, 2019, 02:29:43 PM
I picked up a clear plastic tube of lip balm for the "Flash Mod Gray Tube".
synchro1
Re: Gyroscopic Inertia Generator
« Reply #62 on: November 16, 2014, 05:08:15 PM »
[size=0.85em]
Quote[/li]
[li][/size][/font]
@Tinman,
Joseph Newman has reached the limit you speak of. I attached a picture of his three ton electric motor below:
@Milehigh,
The magnet core output coil Conradelectro tested needed to be SHORTED to achieve the "Lenz Propulsion" effect I forecasted. You impudently prevented Conradelectro from testing the coil with a capacitive load as I instructed him to, causing me great embarrassment, and failed test results. Doug Konzen clearly demonstrated the same effect in this video:"
I refer to the magnet core power coil as an "Output Coil" because it's channeling flyback to the capacitor like Tinman's.
Thanks to Tinman for picking back up where Conradelectro chickened out and dropped off with his magnet core power tests.
