marathonman
This graph pretty much say it all. like it or not this is physics facts at it's finest.
Marathonman
seaad
@ marathonman, all
I have some questions for you:
History from various forums:
Figuera Input 100 Volt --> 100 W Input / Output: 10 kW - 20 kW ( a motor and some bulbs)
Is it DC Watts input??
If so the summary load (Z) resistance in all primarys + G is 100 Ohm
and the  mean input current is 1 Ampere    ( P= U x I )
Quote from http://www.aboveunity.com/thread:
"Please remember folks, the primaries are ONLY reduced to clear the secondary then back to full potential as the other primary is reduced. at NO time is the primaries reduced past 50% or to zero. if you do this induction will fail as the compression of field lines is or was not maintained thus induction will fail and the output will plummet to almost nothing."
" the primaries reduced to 50% "
What?? : Power, Voltage, Current, B
Regards Arne
marathonman
I am really curious if you read the posts or even understand them. i have posted at least 50 times that the current is reduced by part G's inductance, what part of this do you not understand.
" the primaries reduced to 50% " Good god that is not what i said, i said "NOT REDUCED PAST 50% AND NEVER TO ZERO:
NOW ! can you understand that.
For the last time the primaries are only reduced to clear the secondary then back to full potential. if you can not understand that i will never respond to any questions from you again Mr thick as a brick. pay attention, take notes or bow out of Figuera.
Marathonman
seaad
@ marathonman
Thank you for your clarification.
History from various forums:  Figuera Input 100 Volt --> 100 W Input / Output: 10 kW - 20 kW ( a motor and some bulbs)
I have calculated an output  value of about 12.5 Watts see below pic.
According to my simulations it's possible to reach about 70% (70W)
With straight cores according to pic. 2
I got n=70%
And in the same test, with DC added so the bottom input signals tops reached well above the zero line. (0 Volt) exactly the same (AC) N=70% was produced.
But if I add the DC power to that result, only some  % was reached.
Please explain to me , us      HOW? the extra 10 kW - 20 kW arises.
Regards Arne
marathonman
I have enough money to fly to your country and eliminate you so i would suggest you F-in delete my name at once you fucking prick. i am a expert in rifle and pistol and can take you out at over a mile a way so if you value your freedom i would suggest you delete my name fool.
next time i will not be so Nice ass hole Arne.
Marathonman
