New version of flotation device
Started by Floor, May 31, 2019, 03:03:00 PM
telecom
This may work, but ideally would be nice to allocate weight to each element,
to make it possible to use some rudimental math.
Floor
@ Telecom
I will follow your recomendation / request.
   thanks
            floor
Floor
@ telecom
the energy density is, as should be expected very low, because gravity is a weak force.
assume:
float = 3 meters length by 0.33 meters radius.
approximate 10 feet by 1 foot
cylinder of 0.33 meters diameter or
0.165 meters radius  by 3 meters length
=  0.25669285714285694 cubic meters of water.
0.2566 cu meters of water = 256.6 kilograms of weight or
565.7062 pounds of weight.
256.6 kilograms = 2516.3864 newtons.
assume :
float chamber interior is 10.5 meters height, by 10.5 meters width,
by 0.5 meters depth into the page.
this means that the height of the lifting of the float
=  10.5 meters minus 1 float cylinder diameter.
              this is = 10.5 m - 0.33 m = 10.17 m
the float is lifted to a total of twice this distance
    10.17 m x 2  =  20.34 m  total height of the float
2516.3864 newtons x 20.34 meters = 5214.899376 joules of energy stored
as weight of the float external to the fluid chamber.  OUTPUT
assume:
It requires 25 kilograms of force or  245.1663 newtons, over a displacement of
3 meters to INSERT the float.
               245.1663 newtons x 3 meters = 735.4989 joules of work
3 meters to REMOVE the float.
735.4989 newtons x 2 = 1470.9978 joules input work / energy.  INPUT
assume:
It requires 25 kilograms of force over a distance of 0.33 meters to initiate / accomplish
the 180 degree rotation of the device.
25 kilograms =  245.1663 newtons
245.1663 newtons x 0.33m = 80.904879 joules of work
assume:
a 180 degree rotation of the device.
245.1663 newtons x 0.33m = 80.9048 joules of work
there are two 180 degree rotations during each complete cycle.
80.9048 joules x 2 = 161.8097 joules           INPUT
1470.99 joules input + 80.90 joules input = 1551.9026 joules total input
5214.89 joules of energy stored
as weight of the lifted float, while external to the fluid chamber.
5214.899376 joules of energy stored - 1551.9026 joules total input
= 3663.0951 excess energy.
assume: a slow operation time to store that energy (not to use it) of 2 minutes.
3663.0951 / 2 = 1831.5475 joules per minute.
1831.5475 joules per minute = 30.5233 watts
conservatively arrived at this is 30.5233 watts total output
                     or
43,920 watts over a 24 hour period.
Floor
OR
0.25669285714285694 cu meters =  67.78 gallons per two minutes
this is 33.89 gallons  lifted to a 20 foot height per minute.
         floor
telecom
In step 1, when you insert the float laterally, work needs to be done to expel amount
of water equal the weight of its volume, upward.
