Real Free Energy from magnets !
Started by r2fpl, March 09, 2020, 09:21:54 AM
lltfdaniel1
Regarding self running gyroscope with excess torque manifest, your going to need to understand the oscillator effect to comprehend it much better.
The oscillator effect is internal not external, if you do it external it will kill the whole potential of the gyroscope which is what got it to self run with excess torque manifest due to internal manifest.
So to get energy from it regarding excess torque manifest without killing the potential of excess torque manifest it has to be importantly internal.
This is why overunity is considered impossible because of the way the potential of excess torque get's fully killed off and fully prevented because of the laws of energy done by external tapping technique, but with internal technique it has enabled the impossible, with the way the gyroscope has torque manifest which it does means it has done it via internal and actually manifests unlike external where it would be killed off so there would be no excess torque appearing regarding external methods/ the gyro scope design is whole heartily internal.
You can indeed multiply the excess torque in a perpetual sense indeed, where the more you increase or multiply perpetually meaning you get a perpetual torque increase every time and is ultimately more out than in and the out factor gets longer and longer or more and much more which means instead of cop 2 if multiply you would get cop 5 and again cop 14 like that in a way the cop increase is not equal at all as you multiply but in unequal sense gives more perpetual torque or power and the excess torque can be fully be used in that way because the laws of energy if done external would mean again no excess torque manifest but the gyroscope does have excess torque manifest because it is internal not external.
The torque manifest of the gyroscope can be manipulated with techniques so yeah because it is free form torque or torque Precession or torque-induced but still yeah indeed possible.
https://www.youtube.com/watch?v=n5bKzBZ7XuM
Dan.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
The two magnets are fixed by a (Nylon -?) fiber/string
The next trial can be :
Knowing about the Adams motor/NZL ( Tim Harwood CD-motor )  and the Winter disc motor/AT :
the permanent magnets ( the linear pm couple or the round magnets)  horizontal on a rotatingable paper/plastic disc  ( unused CD- disc ?)fixing
and this disc fixing like the "basic concept" : hanging disc
and doing the same CW and CCW behaviour experiment  !
Then with 2 identical /same  fixed discs-pm
Then with 2 discs-pm with one to other 90° placed relation ~ X, next 180° placed relation = from above = cross
Then the disc rotatingable on a desk and with the  permanent magnets fixed !
Happy making results wishing !  ;)
Later,after experimental success : some options
DE2848427 and   DE3602039
lltfdaniel1
Regarding gyroscope when you input movement or torque to make the gyro to start spinning it holds on to that torque which is how the gyro spins and operates as you know but at some loss meaning it will eventually stop spinning if you apply no more torque to it , but when the gyro spins round and round exactly how the earth rotates then that is where the real power torque lies and if you can use that torque and put it in the bit where you made it to start spinning it will spin faster and faster to no end and will never stop spinning or accelerating in that effect right up to the equal mass rotation of the earth
However this real power torque that the gyroscope inhibits works like this, it operarates a cop over 1 but the efficiency i think is under 100% if not then regarding cop over 1 from earth rotation in the gyroscope, the gyroscope would not rotate or work like the earth if the cop was under 1, the fact is you can use all of this cop over 1 to get it to self sustain with excess left over power, i mean the reused cop can indeed over come the efficiency losses and over power it with excess left over power and what happens is you have a self runner with excess left over power which would be used to power a load and never stop working in this sense.
The operation of the gyroscope is both internal and external.
Anyways the gyroscope is a interesting device and good for physics learning but the method of the gyroscope as to how it holds onto the torque regarding the whole spinning process of the gyroscope with some losses is interesting.
It is hard to explain the gyroscope with complex science explanations so keep it simplistic.
But regarding the torque of earth rotation in the gyroscope is it at a loss or a gain?
If at a loss the gyroscope would not work, but at a gain it works as it fully does.
lltfdaniel1
I am wising up as to how it works,
There is a unequal gain to self sustain the rotating s power of the gravity spin of the earth where real work can be done but you will be unable to get any real work out of it.
The unequal gain by passes the losses to self sustain it rotary spinning orbit just like it does in friction less space but with friction here on earth so that process regarding the unequal gain process, the unequal gain neutralising the loss of friction but the friction will still be there to enable no loss effect which is 100% and thus the gyroscope works.
Not every aspect of the gyroscope has that effect i reckon but ponder with that idea, if the entire losses of the gyroscope was accomplished this way then (by bypassing it) well yea you know what would likely happen.
maybe the gain can be manipulated but just a theory.
This understanding will pave way to much more efficient near over unity machines which i think will be more powering saving then what is currently on the world market.
Dan
You are unclear in your statements,lltfdaniel1 !
Is an energy gain extractable ? Yes,but the specific energy kind : space-time ,has to be defined for the right and effective conversion  !
It is a similar problem like by wind generator : too low or to strong ! A storm would give maximal output : but by storms wind genertors mainly becomes automatic stopped !
And this is : appropriate engineering,included power source and demand source harmonizing  !
