RANT CAFFE ASYLUM
Started by WhatIsIt, September 06, 2020, 10:09:59 PM
FriskyFritz
ramset maybe you can fund a team to save all the starving people of the world or may be vaccinate them
which one is your goal
your high horse FriskyRamset is not ever what you claim
cop 1.7 is easy, its achievable for even you but you choose not to try and your paid team is too
achieve don't complain
Stefan's goal is as mine is to educate others on whats possible
it is in his statement
you have no path forward, you demand others, we say no, you cry
I cry for you, I hope he has mercy on you
Fritz
FriskyFritz
Chris gave you the path forward
you refuse to participate
you refuse to get your vaccination team involved
you complain
you do not ever achieve
you loose
Fritz
Quote from: EMJunkie on April 23, 2020, 06:52:38 PM
My Friends,
I started Partnered Output Coils - Free Energy back in January 2015. It was a success and Partnered Output Coils is now part of every serious Experiment today!
While some struggle, others report great success.
The biggest problem we had was, we could have done the release and Introduction with several hundred less pages on Stefan's Forum! Far too many trouble makers! Yes I could have handled myself a little better, but when one gets Attacked all the time, one tends to get a little defensive.
We Introduce: Partnered Output Coils - Builders Group
Chet ( Ramset ) and I are the moderators. There will be opposition, there will be some that don't like being moderated, we will be fair, we will only moderate what we need to! We aim to keep the Trouble makers out and the Motivation High!
No one is twisting your Arm, you join in and participate if you want to! This is your Choice! If your not participating, then please refrain from posting. We want those that have experience posting and all here to help each other.
   1: Off Topic Posts will be deleted!
   2: Posts containing Harassment will be deleted!
   3: Slanderous Posts will be deleted!
I urge all interested parties, Gear Up, we are gonna break new ground! I will do the best I can to help others here! My Team must always come first however, but I am serious, I want every human being on the planet to have the opportunity to learn something amazing and simple!
   1: Input Coil - 10% Duty Cycle starting at about 3 Volts into 25 turns 1.2mm Wire.
   2: Secondary Coil - 70 - 200 Turns 0.8mm wire - Opposes the Primary, use the Right Hand Grip Rule.
   3: Tertiary Coil - 70 - 200 Turns 0.8mm wire - Opposes the Secondary Coil, Assists the Primary Coil, use the Right Hand Grip Rule.
Make sure you have nice clean switching on your Input Coil. You need a Voltage Source that you can turn up, this is important to see the effects.
I have coined a term: Delayed Conduction, I have many hundreds of very detailed articles on my Forum: http://www.aboveunity.com, please use the pages there for reference! Please use: Builders Guide to Aboveunity Machines for extra help!
Remember: Greater than 90% of the time, your Input is Off, this means your Output should be Off, there is no way for your Output to be On is there - Well yes, this is where Science has no proper explanation for whats occurring! One of many gaping holes in Electromagnetics! Let me tell you something very important:
   1: The Change in Magnetic Field Creates a Voltage!
   2: The Opposition of Magnetic Fields Pumps Current!
   3: The term Magnetic Fields is Interchangeable with Current, as a Current is the same thing / Creates a Magnetic Field!
Your Coils must be Loaded at all times, or this will not work! It is advantageous to think: Action, Reaction and Counter-Reaction!
We have a Historical Record to support Asymmetrical Regauging, as long as one can get the Potential, Voltage sufficiently high enough: I = V / R, then your machines will produce: Above Unity Results!
Don Smith:
https://www.youtube.com/watch?v=4qqQarHd74s
The MEG Team:
https://www.youtube.com/watch?v=no50_5iSr2Y
Tinman:
Quote from: tinman on June 25, 2015, 08:25:39 AM
What-you mean like the below scope shot's?
First scope shot before the diode.
Second scope shot after the diode,and large cap removed.
EDIT: Below, see Before and after Diode.
Graham Gunderson:
https://www.youtube.com/watch?v=aQVhMu2FzSg
I have done a video series, to try to explain Partnered Output Coils, the effects, what to look for, how to solve problems and how to make the Coils Act and React together in an advantageous way!
   1: https://www.youtube.com/watch?v=VUemDvugl4I
   2: https://www.youtube.com/watch?v=8LtTerstCxU
   3: https://www.youtube.com/watch?v=SWlLiiIyUOw
   4: https://www.youtube.com/watch?v=k5RoEnmDrR4
   5: https://www.youtube.com/watch?v=sTr6dxD61uw
   6: https://www.youtube.com/watch?v=fFIgo7pj9bY
   7: https://www.youtube.com/watch?v=pKFo4dOW4UU
   8: https://www.youtube.com/watch?v=tUaLp0E2L3s
   9: https://www.youtube.com/watch?v=Gs_e_aU5loc
   10: https://www.youtube.com/watch?v=DdwNiaEuUrg
   11: https://www.youtube.com/watch?v=CRduG2PNIgk
The Sawtooth Wave Form is the defining Energy "Generation" Waveform! Please, always keep this in mind! Think in terms of Energy "Generation"!
You need to think in terms of Symmetry vs Asymmetry! A Symmetrical System can Never Go Above Unity! Your System needs to be Asymmetrical, this is a requirement to be able to "Generate" excess energy beyond the Unity Boundary! Its worth Bench-Marking your machine in Transformer mode, making sure you have around 80% Efficiency at least. Then anything above the 80% mark you can verify, has entered the System beyond the Benchmark value!
As I have shown for many years, Partnered Output Coils must oppose, must Buck each other, there is a specific Polarity to this and the polarity needs to be right. Then you need to focus on the "Generation" Phase, and maximise that phase, remember: I = V / R, Ohms Law. Keep in the back of your head, nearly all the Energy "Generation" Phase is done when your Input is OFF! Thus the short Duty Cycle.
NOTE: Your Machine Pumps Current for almost 100% of the Cycle, but your Input is only on around 10%, or less, so > 90% of the Cycle, you have Energy Output, Energy Output when your Input is OFF, this is significant!
If you only take one thing from what I have posted, please take the following sentence:
Its all just an Understanding, think Asymmetry, forget Symmetry. The Magic happens when you break Symmetry! Action, Reaction and Counter-Reaction!
I hope we get a good response from everyone! Good intentions bring forth Good Intentions, but also brings not so good Intentions, thus why we will Moderate. Please think twice before posting.
Please Remember: This is a Builders Group, if you are not building, then if you can make sure you only post useful, serious discussion, you think that would be helpful for others!
I would like to personally Invite Tinman to join us, that is if he wishes.
Best wishes, stay safe and well,
   Chris Sykes
WhatIsIt
Emjunk,
Did you ever considered that bucking coils works only
in your town OXENFORD, Australia?
Maybe it is Geo related and does not work anywhere else in world?
FriskyFritz
it appears you are threatening other members
publishing private information on members is a broken rule
breaking forum rules again
Stefan ban whatisit for breaking forum rule
I have notified Chris and he might take this to his lawyers for further action
notify the police
depending on what Chris decides you might be in real trouble here
you might be off to gitmo sooner
Fritz
Quote from: WhatIsIt on September 15, 2020, 04:27:59 AM
Emjunk,
FriskyFritz
Quote from: onepower on September 11, 2020, 08:37:36 PM
Whatisit
No offense, but even though I am critical of EMJ like many others you seem to have jumped headfirst off the deep end into a pool with no water. Do you not have more constructive ways to spend your time because this is kind of absurd.
Terms and Conditions
« on: September 15, 2008, 12:40:28 AM »
1. Introduction
The Website Owner, including subsidiaries and affiliates ("Website" or "Website Owner" or "we" or "us" or "our") provides the information contained on this website or any of the pages comprising the website ("website") to visitors ("visitors") (cumulatively referred to as "you" or "your" hereinafter) subject to the terms and conditions set out in these website terms and conditions, the privacy policy and any other relevant terms and conditions, policies and notices which may be applicable to a specific section or module of this website.
2. Information on the Website
Whilst every effort is made to update the information contained on this website, neither the Website Owner nor any third party or data or content provider make any representations or warranties, whether express, implied in law or residual, as to the sequence, accuracy, completeness or reliability of information, opinions, any share price information, research information, data and/or content contained on the website (including but not limited to any information which may be provided by any third party or data or content providers) ("information") and shall not be bound in any manner by any information contained on the website. the Website Owner reserves the right at any time to change or discontinue without notice, any aspect or feature of this website. No information shall be construed as advice and information is offered for information purposes only and is not intended for trading purposes. You and your company rely on the information contained on this website at your own risk. If you find an error or omission at this site, please let us know.
3. Trade Marks
The trade marks, names, logos and service marks (collectively "trade marks") displayed on this website are registered and unregistered trade marks of the Website Owner. Nothing contained on this website should be construed as granting any licence or right to use any trade mark without the prior written permission of the Website Owner.
4. External Links
External links may be provided for your convenience, but they are beyond the control of the Website Owner and no representation is made as to their content. Use or reliance on any external links and the content thereon provided is at your own risk. When visiting external links you must refer to that external websites terms and conditions of use. No hypertext links shall be created from any website controlled by you or otherwise to this website without the express prior written permission of the Website Owner. Please contact us if you would like to link to this website or would like to request a link to your website.
5. Public Forums and User Submissions
The Website Owner is not responsible for any material submitted to the public areas by you (which include bulletin boards, hosted pages, chat rooms, or any other public area found on the website. Any material (whether submitted by you or any other user) is not endorsed, reviewed or approved by the Website Owner. The Website Owner reserves the right to remove any material submitted or posted by you in the public areas, without notice to you, if it becomes aware and determines, in its sole and absolute discretion that you are or there is the likelihood that you may, including but not limited to -
5.1 defame, abuse, harass, stalk, threaten or otherwise violate the rights of other users or any third parties;
5.2 publish, post, distribute or disseminate any defamatory, obscene, indecent or unlawful material or information;
5.3 post or upload files that contain viruses, corrupted files or any other similar software or programmes that may damage the operation of the Website Owner's and/or a third party's computer system and/or network;
5.4 violate any copyright, trade mark, other applicable Germany or international laws or intellectual property rights of the Website Owner or any other third party;
5.5 submit contents containing marketing or promotional material which is intended to solicit business.
5.6 All original content posted by a user becomes "public domain knowledge" and can not be patented anymore.
5.7 Hartmann Multimedia Service does have the right to compile summary articles from the forum postings
for easier reading and summary purposes.
5.8 Hartmann Multimedia Service does have the right to compile archival CD/DVDs for database storage and
distribution to people which have weak online access just charging work expenses and shipping charges.
No charges will be made on the content.
5.8 Content which was posted to the forums can be edited for changes or typos for 1 hour.
After this period you must post a new message to update your postings.
This ensures the verification of timing events and prevents data misuse and data manipulation at
a later time. If a user wishes to delete his content after this 1 hour period he has to apply
by email for it.
( If you are not sure, if you want to have a posting to stay in the forum, please donÂÃ,´t post !)
6. Specific Use
You further agree not to use the website to send or post any message or material that is unlawful, harassing, defamatory, abusive, indecent, threatening, harmful, vulgar, obscene, sexually orientated, racially offensive, profane, pornographic or violates any applicable law and you hereby indemnify the Website Owner against any loss, liability, damage or expense of whatever nature which the Website Owner or any third party may suffer which is caused by or attributable to, whether directly or indirectly, your use of the website to send or post any such message or material.
7. Warranties
The Website Owner makes no warranties, representations, statements or guarantees (whether express, implied in law or residual) regarding the website, the information contained on the website, your or your company's personal information or material and information transmitted over our system.
8. Disclaimer of Liability.
The Website Owner shall not be responsible for and disclaims all liability for any loss, liability, damage (whether direct, indirect or consequential), personal injury or expense of any nature whatsoever which may be suffered by you or any third party (including your company), as a result of or which may be attributable, directly or indirectly, to your access and use of the website, any information contained on the website, your or your company's personal information or material and information transmitted over our system. In particular, neither the Website Owner nor any third party or data or content provider shall be liable in any way to you or to any other person, firm or corporation whatsoever for any loss, liability, damage (whether direct or consequential), personal injury or expense of any nature whatsoever arising from any delays, inaccuracies, errors in, or omission of any share price information or the transmission thereof, or for any actions taken in reliance thereon or occasioned thereby or by reason of non-performance or interruption, or termination thereof.
9. Use of the Website.
The Website Owner does not make any warranty or representation that information on the website is appropriate for use in any jurisdiction (other than Germany ). By accessing the website, you warrant and represent to the Website Owner that you are legally entitled to do so and to make use of information made available via the website.
10. General
10.1 Entire Agreement.
These website terms and conditions constitute the sole record of the agreement between you and the Website Owner in relation to your use of the website. Neither you nor the Website Owner shall be bound by any express tacit or implied representation, warranty, promise or the like not recorded herein. Unless otherwise specifically stated these website terms and conditions supersede and replace all prior commitments, undertakings or representations, whether written or oral, between you and the Website Owner in respect of your use of the website.
10.2 Alteration
the Website Owner may at any time modify any relevant terms and conditions, policies or notices. You acknowledge that by visiting the website from time to time, you shall become bound to the current version of the relevant terms and conditions (the "current version") and, unless stated in the current version, all previous versions shall be superseded by the current version. You shall be responsible for reviewing the then current version each time you visit the website.
10.3 Conflict.
Where any conflict or contradiction appears between the provisions of these website terms and conditions and any other relevant terms and conditions, policies or notices, the other relevant terms and conditions, policies or notices which relate specifically to a particular section or module of the website shall prevail in respect of your use of the relevant section or module of the website.
10.4 Waiver.
No indulgence or extension of time which either you or the Website Owner may grant to the other will constitute a waiver of or, whether by estoppel or otherwise, limit any of the existing or future rights of the grantor in terms hereof, save in the event or to the extent that the grantor has signed a written document expressly waiving or limiting such rights.
10.5 Cession.
The Website Owner shall be entitled to cede, assign and delegate all or any of its rights and obligations in terms of any relevant terms and conditions, policies and notices to any third party.
10.6 Severability.
All provisions of any relevant terms and conditions, policies and notices are, notwithstanding the manner in which they have been grouped together or linked grammatically, severable from each other. Any provision of any relevant terms and conditions, policies and notices, which is or becomes unenforceable in any jurisdiction, whether due to voidness, invalidity, illegality, unlawfulness or for any reason whatever, shall, in such jurisdiction only and only to the extent that it is so unenforceable, be treated as pro non scripto and the remaining provisions of any relevant terms and conditions, policies and notices shall remain in full force and effect.
10.7 Applicable laws.
Any relevant terms and conditions, policies and notices shall be governed by and construed in accordance with the laws of Germany without giving effect to any principles of conflict of law. You hereby consent to the exclusive jurisdiction of the High Court of Germany in respect of any disputes arising in connection with the website, or any relevant terms and conditions, policies and notices or any matter related to or in connection therewith.
10.8 Comments or Questions.
If you have any questions, comments or concerns arising from the website, the privacy policy or any other relevant terms and conditions, policies and notices or the way in which we are handling your personal information please contact us.
11. Copyright
11.1 It is forbidden to post copyrighted material. You can only post your own material
where no third party has any rights on it.
By posting your own original material you waive the rights to any copyright and you agree
to put it into the public domain. Then it is not anymore patentable.
11.2 All changed template graphics, buttons, icons, logos, layouts and look & feel, which are changed from
standard templates, are the copyright of Hartmann Multimedia Service, unless expressly acknowledged as otherwise.
11.3 The data mining, extraction or utilisation of product information from our website is not permitted without our express prior written permission.
Keywords - Website Legal Documents
legal, legal documents, website legal documents, privacy policy, privacy notice, copyright notice, terms and conditions, terms of use, hosting, terms, conditions, agreement, website documents, legal docs, disclaimer, law, trademark, free website legal documents, commitment, information, data security
https://youtu.be/xmJr4_gHygo
https://youtu.be/FSsmScZqMts
https://youtu.be/fpcqMPvcoW0
Quote from: tinman on June 20, 2015, 02:46:47 AM
I have done this many times over the years,and yet no one wanted to really know about it,nor was much interest shown.
The L.A.G
The rotary transformer-->along with a few others.
Using the bucking coil configuration, coupled in with PM's on a stator that attract an electromagnetic field of a rotor,but appose the generated field of a generating coil,it would seem that the overall output has exceeded that of the input-->and i am pretty up to date on measuring P/in and P/out with DC system's ;) The latest setup seems to show a COP>+ without even having to try and measure the mechanical output to the fan. That output would be just an additive to the output. By removing the fan,the P/in go's down,and the P/out to the resistive load go's up.
But here your damed if ya do,and damed if ya dont.
So i post a video here showing what i have,and it show's a COP>+ --> then what? ::)
Yes-all the crap starts (as it has so many times before).
People want all the details,so as they can start there build of there own COP>+ device.
They take short cut's,and dont follow instructions,and when there device dosnt work,they call you a fake-->or the device works as stated,and now some rich prick patents the device,and were all screw'd,and im left with nothing more than i have today despite all my hard work over the years.
So rather than post all the details here MH,and have others profit from my hard work(as we seen in the case of SEC exciter being pilfered by teslatronix) How about i just post a video of the device running,and show how i am calculating my P/in and P/out-->would that be acceptable?.
From there you can pick it apart as much as you like.
Quote from: tinman on June 18, 2015, 07:15:52 PM
It would seem that a bucking coil arrangement dose indeed add energy to a system. My test over the years have shown this to be true,but all my devices that use this arrangement are mechanical--E.G-,motors,generators.
Quote from: tinman on September 16, 2015, 12:05:20 AM
Many here laugh at, and mok EMJ, but the fact is , he is basically right in what he is trying to put forward.
https://www.overunityresearch.com/index.php?topic=3319.msg56743#msg56743
Quote from: Grumage on 2016-08-08, 11:27:56
Ah..... It seems Brad beat me to it!
Should I open a topic? " Do permanent magnets DO work "
Consensus?
Cheers Grum.
I think it is time Grum,to answer this question once and for all.
For every action,there is an equal and opposite reaction--and then there is the counter reaction
Open the topic,and lets get ION on the scene ,as he knows his way around calorimetry setup's,and i believe this is the way to show PMs doing useful work.
Brad
Quote from: tinman
https://www.overunityresearch.com/index.php?topic=3319.msg57155#msg57155
PM
How closely do you think this is starting to resemble EMJs partnered output coil setup?,as i am seeing some resemblance here.
Brad
feel the pain
listen for the pointless noise on the way out
