Re: Self Looped Cap Dump Bedini Motor
Started by Dave Wing, September 01, 2023, 08:24:58 AM
Dave Wing
Here you have two Watson Machines, the larger one has the 3 coil arrangement with the offset magnet rotor that gives you the asymmetrical waveform, the small one appears to have no offset arrangement only ring magnets.
The Bedini SG is an all in one machine that was based upon John's 1984 book called "BEDINI'S FREE ENERGY GENERATOR". It is the same machine built by Jim Watson. They are all motor generators, the SG is the same,  it generates while running. When you set up the machine with the asymmetrical magnets or use the three coil setup as found in John's Ferris Wheel, you can generate the same waveform as the Kromrey converter which generates using low drag generator stress fields.
The SG can produce the same waveform as the Kromrey Converter when you use the asymmetrical magnets.
Dave Wing
Dave Wing
Chris Sykes also had this to say about the magnetic gating of stress fields in an asymmetrical magnetic arrangement.
Dave Wing
Here is the waveform that is the same as half of a Kromrey Converter, produced by two magnets and Bedini SG circuitry.
Dave Wing
The Bedini SG does send a charge to the primary and secondary batteries, if the primary coil can generate enough voltage to overcome the batteries voltage. I screen shot two circuit images of the SG, below they both produce the same results to the primary and secondary battery.
-Diode One (1N4001) rectifies the negative half of the north magnet waveform and sends it to the primary battery.
-Diode two (1N4007) rectifies the positive half of the north magnet waveform and sends it to the secondary battery.
The North Pole waveform has two emf's, one positive and one negative, that are diverted into two different pathways using a one wire coil.
In the first image of the Bedini SG circuit the negative half of the waveform is sent to the primary battery if the coil can generate a high enough voltage to over come the primary battery voltage. If the positive waveform is clipped it is sending a charge to the primary battery, if it is not clipped no charge is going to the primary battery.
The images below offer the same results. Also don't forget your inductive coil collapse which also goes to your secondary battery on top of the positive half of the clipped waveform.
Dave Wing
Here is a simple test to prove what I said above, there are two induced voltages, one positive and one negative.
