Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Mannix
The trouble with decetiopn is that the deceiver can never believe any thing that any body ever tells tem ever again.
Great little torriod experiments going, on they look just like the centre coils almost  in all the videos...
EMdevices
starcruiser
Carl
wattsup
Just spiked it with 3 vdc and counted 2 minutes 40 seconds. Now I can play, or should I say, "Oh no, not more homework".
@Mannix
Do you think you can re-write your first sentence more clearly.
As for the center coils, I saw that right away, this could be the TPU start up.
@alls
Questions:
1) Since I do not see the led blinking, does this mean that the transistor base is always receiving a current from the trigger coil.
2) If the transistor is acting like an amplifier, what if you put more transistors in a row. I guess you would still need more power to run more bases.
I can't wait to get some real ferrites.
I want to also put open ended collectors or plates, one on each side of the large capacitor. Like the Tesla radiant energy patent uses a cap and some mechanical switching.
Found this guy on ebay from Lithuania. Lots of neat do-dads.
http://stores.ebay.com/KW-TUBES/
Does anyone know what this is? Russian Military Grade klystron K-166B
http://cgi.ebay.com/REFLEX-KLYSTRON-K-113-Military-grade_W0QQitemZ200174270045QQihZ010QQcategoryZ4660QQcmdZViewItem
@EM
About your PS: on the Discussion thread, if this little bugger can really start to move stronger currents, you could make your own vortex.
abassign
@wattsup
@EMDevice
@sanmanki
I propose a simple test:
To replace the condenser from 1000 mF with a smaller, for instance 500 mF, so that to verify if it varies the duration of operation on the device and than it varies.
The test can be repeated reducing the condenser more and more.
Is possible to repeat the test with a bigger condenser.
With this test it is possible to clarify the origin of the energy of operation, if the time of operation tightly depends on the consenser capacity, it is evident that the condenser from 1000mF plays a fundamental role. Otherwise it is very probable that energy comes indeed produced by the spool.
is it possible to replace, in the circuit, the transistor with a MOS-FET for instance 2N7000 ?
