Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Liberty
Wonder if setting up two transistors in a darlington arrangement for this circuit would be of any advantage?
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
Bruce_TPU
@ Liberty
I Googled it and found the circuit.  Wired it in.  It is working and I am timing it.  Will post the results.  Thanks for the idea!
Now if you can tell me how to further amplify the signal, that is what I would like to try.
Cheers,
Bruce
Liberty
@Btentzer,
Your welcome.  I don't know if it will help, but it gives the pair of transistors higher gain while acting as one transistor.  The base circuit can be switched on with less current and the output circuit likes a low impedance load.  Here is a diagram of a couple of NPN transistors connected as a darlington pair.  PNP can also be hooked up the same way.
Liberty
Bruce_TPU
@ Liberty
Thank you for the drawing.  My last test, I had it wired wrong.  I connected according to your drawing, but left the collector off of the lead transistor.  The circuit would not work with it in.  Please don't ask why!  LOL
The LED's blinked, very brightly for 2 minutes and three seconds and then went dark.  Good try, keep thinking!
Cheers,
Bruce
I have now tried this also,
but just with 3 litz coils on my ferrite rod.
I can get a steady oscillation going for over 3 Minutes and
then the 1 blue LED I am using still
shines about 2 minutes more...
But I have to compare it with a to 12 Volts charged 2000 uF
capacitor hooked up via a 4.7 KOhm resistor to the same
blue LED. This DC discharge will light the LED also about 3 minutes...
and this is then only the cap and the resistor and LED...
so as these LEDs are pretty efficient, wehave to find out,
if the MicroTPU circuit is really giving us more energy
or if only the energy of the cap is used up in
a much longer time...
So as I am very tired, I am going to sleep now and continue
later... It seems , my circuit can go with a bit tweaking still
a bit longer, maybe 10 minutes...
Have to check it out...
At least it will work also with litz  coils
oscillating in the 1Mhz range.
Oscillation looks quite like a sine wave.
I am using a BC 555 C  transistor and about 2050 uF
as the buffer caps.
Regards, Stefan.
