Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
plengo
ah one thing I forgot to mention on my previous post. One of the batteries I used on my tests where it started with 6.16v and end-up with 6.80v. I let it sit for 2 days now and its voltage is the same as when I left. So, it seams that one of my hypothesis is correct where the battery after some usage would comeback up to a certain level and stop unlike what is happening when we leave it running on the the circuit.
Very intriguing indeed.
I also, a long time ago, with another circuit of mine (I have youtube videos of that one) ran a Lead-Acid 12v 5ah battery SLA with another circuit of mine and I had even better results where the battery would go up and stop solidly at 11.29v.
I could run the circuit for days and it would simply stop there. I would totally discharge it to the point of damaging the battery (about less than 2v) and still it would work and stop at 11.29v.
So it seams that this effect is very relevant to the whole frequency/oscilation thing on different kind of batteries. It is in my plan to once seattle this NIMH battery tests I will go to the bigger one and hopefully extract even more power out of it.
Fausto.
ps: Last reading is 8.12v (I started it yesteday at 7.15v at 9pm with a brand new 7v NIMH out of the box battery - I just bought 25 of those on ebay for one buck each).
Bruce_TPU
Great stuff Fausto!   ;D
I was thinking either larger batteries, or dead 9volts in parallel would make for a good test.
If I were not seeing this with my own eyes, I would be very skeptical.  It is very strange, that the longer I run my circuit the more the battery charges.
As of :
11:46          7.25 volts        (as expected!!   ;D  )
hakware
What would happen if you wound the coils like this
01000111010011110100010000100000010100000100110001000101010000010101001101000101
001000000101011101001111010100100100101100100001
Thaelin
   Bruce now has a self charging battery system complete with blinky lights.   :D ;D :o
thaelin
Now I know why I cant get anything done, you guys keep comming up with new things to do.
plengo
