DISSOCIATING WATER, A KEELY Project
Started by hansvonlieven, October 03, 2007, 02:04:46 AM
nightlife
Evil Roy Slade, I seen that video along with the others and I have his patent application downloaded trying to find out the power used to create the affect he did. You may want to use this next link to check it out more.
http://en.wikipedia.org/wiki/John_Kanzius#_ref-rustumroy.com-responsetoemail_0
The one thing that disturbs me is that no one is talking about the effect it had on the florescent bulb that the frequency lit up.
JackDaniels
Hans,
I was doing some out of the box googling and found something that might be worth a try with the apparatus you have.
136.10 Hz @ 432.10 Hz. - This is supposedly supposed to make water vibrate. It's the frequency of OM, the Indian/Buddhist chanting mantra.
http://www.bevnet.com/news/2006/03-24-2006-LiquidOM.asp - This is the souce where I found it as well as various other sources when you google up 136.10 Hz ... there are plenty of tuning fork sales people out there.
Sorry I cannot give you an authoratative affirmition on the frequency but it might just be worth giving a shot. (Ps. Dont know if its sine or square)
I would think this way... if you manage to vibrate the little guys in H20 the possibility of a stretch break with Stan Meyers or the Joe Cell method might actually have a meaning as half the disassociation work is done by the stretching and flexing.
Let me know if this tip was usefuel. (misspelled on purpose)
Jack.
hansvonlieven
Thanks Jack, I will give it a shot
Hans
Goldsphere
None of this makes any sense without taking into account the size of the vessel holding the water,
hence why Stan Meyer used the electrolysis chamber as a capacitor in the circuit. By doing this in
a resonant circuit, he minimized the energy used because it technically wasn't a load on the circuit.
So he would have had a variable inductor to adjust the resonance to find the right frequency.
This would give a limited range, but by making different chambers and inductors, quite a broad range
can be experimented with. Standing waves are created through geometry of the structure.
Meta
Hans,
I've studied Keely for 25 years and studied Physics, Metaphysics, and Religions for as long and read 40,000 books, plus the Internet, for years.
May I suggest some adjustments, if the Dan Davidson recommended frequency of 42,800 Hz (42.8 MHz) is not found to be working. No where in Keely's Articles in very old books, which I have looked through and listed at the end of this post, have I seen Keely mention his 42,800.
I did post with my own email group years ago and documented the emails here:
Electrons and Mythologies
http://www.greatdreams.com/grace/50/99s1.html
If you want to go to webpages 99s2.html and 99s3.html, insert the needed " /grace/ " into the URL of all internal page links, then they will work.
Also, as a note, we found that 440 Hz = A is not a Sacred Science frequency or harmonic of the Ancient System. The frequency of the Kings Chamber, Cheops Pyramid coffer is 432 Hz = A. So if you find that 42,800 Hz doesn't work, try 43,200 Hz (43.2 MHz), a harmonic of 432 Hz. Note that the mass chord of atomics constantly drifts somewhat.
You will also find all the old Articles that Keely and Mrs. Bloomfield published, at this URL under Additional References. You may find these hardbound Indexes at any of the main Repository Libraries in the US:
http://www.greatdreams.com/grace/1/26keely.html
Meta
Impossible Correspondence
http://www.greatdreams.com/grace/index.html
