Hilden-Brand Magnet Motor
Started by JackH, March 10, 2006, 11:58:55 PM
0 Members and 19 Guests are viewing this topic.
Hi JackH,
sounds good, but you have to check, if you have placed the electronic scale at the same
height as the axis-shaft of the motor, otherwise you could get a wrong torque arm angle
at this measurement, which could lead to wrong mechanical output.
So as your 0.021 hp motor is putting out around 15 Watts mechanical power as you claim,
does it only comsume 3 Watts of electrical input power ?
Hello Jack H.,
I do not want to amplify a permanent magnet force,
I want to get an electro-magnet force amplifycation !!!
My question is-parallel to the permanent magnet amplifycation
factor 15X(AMS/AMT),which amplification factor can I get by use
of an e-magnet ?
Sincerely
             de Lanca
Hi De Lanca, amplification of electromagnet is a Flyn type e-magnet.
But that is only for the static case.
If you want to build a motor with it with
dynamic switch on/off of the electromagnet you are "hit"
again with the Lenz law, so that the Counter EMF "gets" you...
If you can reduce the counter EMF via some kind of trick
and so that the motor is just a motor and not a generator,
then you could get overunity mechanical from it.
Hello "Moderator",
yes and no !
IT depends of a vertical/horizontal view /arrangement of the
+/- flux axis !(Molina-Martinez,Remigius Ohlmann et c.) !
The Flynn-concept is Permanent-magnet force amplification
oriented,not electro-magnet as primary source !
Probably on Friday(heute) our CONCEPT-Transmuter is ready to
present the functional X-TRON,so I will get the possibility to
show a kind of closed-M.A.S.E.R.-cycle !
Naja,irgendwo eine Camera auftreiben und wie geht es mit Bildern
"versaendaen" ?
Also bis zur naechsten Pulle
de Lanca
Okay JackH,
so let us get idea,with/by  experiments !
Sincerely
            de Lanca
