"Self Running 900 Watt Fuelless Electrical Generator" Is this new?
Started by bourne, December 16, 2007, 11:07:06 AM
Groundloop
@innovation_station,
I have made a prototype based on my drawing.
The prototype has only three coils to see if the systems work or not.
The motor generator runs and has a output on the magnetic cross coupled
coil. So I conclude that is IS possible to build the motor generator shown in
my drawing. May drawing is NOT a joke, the 600W generators discussed MAY be a joke.
Groundloop.
innovation_station
nice groundloop
i will lable my words*as sarcastic* from now on ......when ment to be lol
ist
Koen1
Groundloop,
so what's the measurements on that prototype?
How much do you put in and how much does it put out?
Does it look like a full version (with not just 3 test coils)
could produce more output than input?
I'm kind of missing that here... Sure it may do something,
but does it do what we want it to do? ;)
EMdevices
nice testbed groundloop.  nice and small and compact !!
are you trying out this concept of resonance?   you should.
EM
Groundloop
@Koen1,
My motor as it is now is only 1/4 of the drawing. I have found that the method of closed loop
magnetic pathways IS working. First (look at the circuit drawing) the magnets is coupled
to each other through the Iron rotor. This will close the magnetic path on the back side of
the magnets. The result is a stronger magnetic field from the magnets. This means one can use
smaller magnets than a normal pulse motor. Now the motor coils is also connected together
with Iron. By doing this the magnetic field from the magnets is free to travel through the iron
thus closing the magnetic path. But since the rotor is rotating the magnetic field in the outher
iron ring will alternate. This will produce power in the generator coils.
I must add that a great source for Iron rotors can be found in AC powered fans.
My setup as it is now is NOT over unity. It runs from a 12 Volt 7 A lead acid battery with the output
looped back to the battery. The current it uses is very low. The battery is depleted very slowly.
Groundloop.
