AETHER VORTEX TPU
Started by FatBird, March 25, 2008, 07:21:53 AM
casman1969
@Sparks
HUH?
The pic is my pulse/Bedini SSG setup and I'm picking off the BEMF for charging two batteries. It merely keeps two batteries fully charged and yes I then rotate the supply to the charge. What I was saying was this. By simply putting a steel (hollow core) pickup coil near those spinning magnets I can produce anything from 1V to 20V which in turn would feed the step up transformer. Transformer low turns side being fed by coil, High turns side produces a HV wave form. Since the topic of this thread is Cliffs' Vortex and it doesn't require high power, I was just wondering out loud if this HV could be used to create the vortex? Of course it would be rectified before hitting the plates.
Carl
sparks
  @Casman
     Sorry I was talking about Cliff''s setup.  I posted a picture below of what I think it is configured as.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
casman1969
@sparks
Sorry.
That is the configuration I got out of it also. There is mention of possibly putting the coil on an angle inside the plates. Will get the disks soon as I can as I REALLY want to play with it.
Have read many of your posts with interest.., keep it up.
Carl
starcruiser
I was reading this thread and wondered if a piece of coax cable would do the trick for the upper and lower plates? hummm...
Carl
vince
Hey Guys:
I've been playing with this thing since I first posted my setup.  I've tried both polarities on the plates and let all the different setups run for almost 2 hours each. My coil has been centered between the two plates, touching the bottom , and also touching the top.  I've tried different spacing between the plates from 1'' to 6". I've installed all kinds of loads from a resistor to various bulbs of all kinds of voltage.
I STILL GET ABSOLUTELY NOTHING OUT OF IT, NOT EVEN A FRACTION OF MILLIVOLT.
Here's hopping you guys can do better !
Vince
