resonanceman
Quote from: jeanna on April 20, 2008, 09:05:22 PM
@Gary, I am wondering if you are calling your coil a cap BECAUSE there is no galvanic reax going on? because you used a dry set up? I am not sure still how, but I am told that the coil is a cap too even when it is running a galvanic battery. In that patent Tesla refers to this too.
Jeanna
I guess   I didn't make  things  very clear.
My first  coil   was  a " normal "  stubblefield   earth battery.
My  second   " coil "   is my cap  ......it is made  for  studying  the  magnetic  posabilities   of  dissimilar metals .
My cap  is made with  sheet metal . .......or in the case of  aluminum.......foil.
The only wire in my  cap is the  connections  for  my meter.
Compared  to a coil it  can be  rebuilt  with  different metals  relatively  quickly .
gary
resonanceman
Quote from: 1tesla01 on April 20, 2008, 09:23:56 PM
Gary, I dont see where it would make any difference ac rf or dc because of the phase shift.This coil has 2 vortexes, 1 regular the other inverted say figure 8 with the bifilar in the middle.Everything is phase shifted and draws energy from the ambient also.In some instances these coils will vibrate profucely with ac and rf havent tryed it with dc.anything that operates with a wave pattern.This coil strips the waves appart.then you have particals and antiparticals that want to go back to ambient.This is zero and some instanaces below zero trying to come back to a normal sine wave this is pure scalar.Remember we are working on the zero point only.Regards Andy
Andy
I just finished   reading  the patent .
I think that  there are alot of possabilitys  relating to  what we  are learning  from  the stubblefield earth battery .
If I understood  your  earlier  post right ........you  said something about  using  large wire .    how much  does that  help ?
WHat I am thinking now ........ to make a non  galvanic  earth battery  I could   start  with a  sheet of plastic .
Hot  glue  copper  and  iron  wires in a spiral  around a  center  hole   ( through the plastic. )
As I see it .........one  coil wound  like this  wouldn't make an earth battery ...............but  ........if I  placed an iron  rod  through the  hole in the plastic   I could  stack as many  coils  as needed  for  any  power requirements .
one  advantage of this is  you can wire each  section or group of sections in either paralell or series
I want to try   to make  a resonant  earth battery ......I need  AC  for another  idea .
The  inductance of the iron  winding of my original  coil  was  quite a bit less than  my copper .      if I understand  the patent  right  I could  add a layer  (  or part of a layer  )   of iron only  to  tune   the  inductance.
gary
jeanna
Andy,
Are you talking about the Stubblefield battery? It sounds to me like the Tesla pancake, a little.
I don't see how we could do the pancake on the core piece, which is likely how NS got away with his design, because otherwize Tesla covered it with his pancake patent.
In case you haven't read it the Stubblefield patent is 600457.
If you have and you are talking about it, wow, it sounds like you have a lot of experience with these.
jeanna
jeanna
Gary,
Just so I can keep up, is this a pancake on the ground?
or stacks of pancakes?
Maple sysrup? ;D
jeanna
Pirate88179
@ All:
OK.  I have been reading the last several posts and (Oh no, not again) may have an idea.  I noticed on the Tesla patent for the pancake coil that all the wire (bifilar) were insulated and, as Jeanna pointed out, no core.  Way back when we were wondering if it was better to have a short coil with many, many layers or a longer coil with a few.  so, what I am thinking is trying a Tesla/Stubblefield set-up whereby you have a pancake bifilar except we use the old bare cu and fe wire insulated with cotton and add an iron core.  The core, of course, would be more like a disk than a rod.  This would be easy to wind.  An old record player would be handy at this point.  Not to use the motor but, you could hand spin it while winding and keeping it flat.  What do you think?  I would like to see what this puts out.
Bill
