Single AA battery to light WHITE LED for long-long time
Started by zon, March 05, 2008, 05:18:40 AM
gyulasun
Quote from: zon on April 29, 2008, 09:37:35 PM
Sorry, here is my latest trial, revision number 14.
Measurement at + battery, 3.6 mA
The battery still drain in certain time but improve the duration.
Hi Zon,
When you measured 3.6mA current from the battery, how strongly your LED (and/or the NE2 bulbs) were lit?  You used one or more LEDs?
What i do is combining my circuit with my friend's free energy charging (FEC) system.
I share FEC'S my friend pict.
Component are :
    3 pcs NE2
    4 pcs Diode 6A2
    6 toys magnet (Rattlesnake sound eggs, made in China)
    Coil SWG 35, 0.2130 mm
    Capacitor 4700uF/25V
    Capacitor 100 nF
    Ferit (not torroid)
Unfortunantly, my friend's not allowed me to share coil setup.
I have try use FEC to charge LEAD ACID BATTERY 6 V 4AH and 12 V 3.5AH.
It's work ! no tricky
Regarding the FEC circuit, can you measure its current comsumption from its own 1.2V battery  when it charges the 6V 4Ah lead acid battery and the 12V 3.5Ah battery?  Also can you check the charging currents too?   And the NE2 bulbs in the FEC circuit are lit when while it charges the batteries?
Thanks for the infos and keep up good work!
rgds,  Gyula
gyulasun
Component are :
    3 pcs NE2
    4 pcs Diode 6A2
    Capacitor 100 nF
    Ferit (not torroid)
Hi Zon,
One more question:  in the above component list for the FEC, I cannot see any transistor (or any active device),  is it NOT needed for the FEC?  And you know how many coils are used, one or more?
The 6a2 diodes are normal rectifier types (like 1n4002) but they are rated for 6A current and 200V, and not at all fast switching types but general purpose, I assume fast diodes are either not needed for the FEC circuit  or  they were at hand in the junk box...
thanks,  Gyula
zon
@Gyula
my LED Circuit:
NE2 not lit.
LED lit as usual (without ne2)
but current drain change, less than without NE2.
FEC:
NE2 not lit,  is act as ion/electron valve only (he said)
No transistor or active component.
if you find fast swicthing diode is better.
i haven't measure the current yet. I'll post later
zon
gyulasun
Hi Zon,
thanks for the answers!
Have you thought if there is no transistor (active component), then what makes the flux change? (because I guess something has to induce voltage in the coil to get output power and the 6 toy magnets have a static magnetic fields only, right?)    A mechanical switch perhaps  or an active device hidden inside the coil??
rgds,  Gyula
EDIT PS:  Can you ask your friend if his FEC is able to run from a super capacitor of 1 or 3.3 or 4.7 Farad, charged up first to 1.2V then connected to his circuit?  Because if it can, it is SURELY an exceptional circuit!!!
zon
@gyula
Absolutely no active component. I saw on he winding before covering with tapes.
We don't try it on super capacitor.
He said this FEC , motionless generator ?
zon
