aleks
Quote from: tagor on May 22, 2008, 05:12:52 AM
this morning , in PARIS, there was an alerte (just like in the last second war)
for a moment I think some one in france was playing with this device ...
but it seems there is no reason for this alerte !!
These alert devices are checked once per year I think, just for the case...
Koen1
Quote from: Inventor81 on May 22, 2008, 01:28:04 AM
Wonder what monocrystalline pharmaceutical grade Lithium Carbide would do?
Ooh Lithium, I like it already :D
To be honest, at first I thought it was important to have the atoms in gaseous state in order
to perform the Protelf reaction, so I had made some rought concept designs of a Lithium
based version, basically heating Lithium in an evacuated glass tube untill it vapourises,
then switch on the B-field and blast a few hundred volts through the vapour.
But as experiments have been performed it seems that at least for carbon it is not
necessary to have a gaseous state, so perhaps Lithium doesn't need one either...
In which case solid Lithium or a conductive compound of Lithium, like the Lithium Carbide
you suggested, should be usable as well. That makes the entire design a lot simpler:
now we only have to replace the carbon rod with a rod of Lithium carbide or some other
Lithium compound, and we should still get even more output. :) But perhaps the rod
needs to be a pure material?
With the recent discovery that there is definately OU but not in all cases beta, and the
suggestion that it could be a special magnetic oscillatory phenomenon, it is interesting
to see if Vall?e's suggested materials still perform in a similar way...
After all, even if there is no measurable beta radiation, it is still the carbon rod in a B field
with a voltage jolt that makes the magic happen, just like Vall?e's suggested setup predicts,
there's just no measurable beta...  So it is plausible that the other materials he suggested
for even greater energy output will still produce more energy, with or withour beta.
In my opinion this is a great setup whether it emits beta or not, because it is already OU
even if the beta is lost. With beta the output could be a lot more, but without it it's already
a self-powering energy producing setup. Or at least, with R's setup it is. ;)
Still, may be worth looking into some tests with Lithium instead of a Carbon rod...?
I am getting a little confused though... some are getting beta, some not, some are getting
clear OU, some not...
@AbbaRue: I was thinking about those liquid hV diodes you made a while ago...
Could we perhaps make an altered version for use with this setup?
I was thinking along the lines of using the carbon rod inside an aluminium tube,
then sealing the entire tube watertight and immersing it in a bath of the sodium-based
solution you used in your diodes, and basically using the aluminium tube as
one electrode and some second material as the other...
The main idea is to use it as a n-p diode-like element, but at the same time the
aluminium tube should be getting hot from heat conduction from the carbon,
and this heat should be exchanged with the solution. Obviously the entire setup of
aluminium tube+solution+container/electrode should get hot, but we can always
apply cooling to this container/electrode, and we could perhaps even use
a thermocouple to get even more usefull energy out.
It was just a wild idea and it may not be very effective, but thought I'd throw it up
anyway. ;)
Quote from: aleks on May 22, 2008, 05:51:56 AM
Yeah it's probably a regular test. We get them every 1st of the month.
It's either that, or the nuclear plant next to Paris went halo and they quickly
killed the automatic alarm. ;) ;D Nah, prolly not.
Quote from: zerotensor on May 22, 2008, 05:18:16 AM
Dang!  Now that's gonna be a party!   I propose we hold the conference in Berlin.  (Stefan, can I sleep on your couch?)
Hey now that's not a bad idea! :D
If we coordinate we can combine it with the citywide rave party in Berlin in summer, if you're into that.
And it would be a good opportunity to practise our German. :)
I say let's do it. And let's print T-shirts to commemmorate the happening. ;)
QuoteAs for the theoretical bets, since all the obvious ones are taken, I'm gonna go out on a limb and say its, "Current-induced beta emission in magnetically-biased bulk graphite arising from cooper-pair-bisoliton recombination at graphene nanocrystal boundaries" -- (or something like that....)
Hahah lol Well it sounds darn good, I'll give you that. :) Especially the extremely convincing "or something like that". ;) :D
sparks
Quote from: sparks on May 21, 2008, 04:28:09 PM
  I don't know if the below tempic differential intelligence of the space-time continuom circuit below is enough to get beta out of a piece of aluminum foil attached to the electron mass storage unit called earth.  I would use a couple of incandescents between ground and a piece of aluminum foil as you try to find out though.  And use caution in manipulation of the foil so you don't short out the spark gap into your body.  :o :o :o :o danger.
@Fenyman
   I guess in keeping with the spirit of things here you could replace the aluminum foil with a slab of carbon.
   I am not sure when the described experiment is done if the bulbs will light if carbon is used.  I would think that the carbon resistance is going to cause the carbon block to heat up though.  Possibly glow red if the carbon block is a point.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Yucca
It would be fairly easy to retrofit existing nuclear reactors to use this tech, hell they've already got the carbon rods in, also you could cut out the heat exchanger and just run the primary coolant straight to the turbine as the water would not get contaminated. Maybe they've already done this but just don't mention it so they can still keep the cost/kwh up. But then again where would they get their precious bomb ingredients from if they did away with the heavy stuff.
DrStiffler
@All
A couple of things please that will help clear my clouded mind a bit (I hope).
1) Who 'now' has OU, OU that they can take a person to the device and show it working, sustained? or intermittent and for what length of time?
2) Is there watching or does someone know a state of the art Industrial Electrician that will comment on the pictures of what is presented as the 60kW Juan device?
I will need to clean up some business after getting back and then get back here and see if I can supply any aid, meager as it may be.
That picture has bothered me, I have seen it before and I want to say a motor control unit or a stage light dimmer, a fellow on the plane with me said the end plated on the coils were Plastic (the grey plates) and they are pressed by 'formed' end plates.
Please don't get me wrong I am not negative or saying anything against this work, but maybe we need to find if the start is real before to much resource is used?
Thanks and back in a couple of hours.
All things are possible but some are impractical.
