Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
Sprocket
Quote from: Les Banki on April 16, 2011, 03:08:26 AM
Further, I am disappointed that THIS Forum allows all kinds of absolute rubbish to be posted, which, IMO, is DELIBERATELY done to CONTINUOUSLY push more important topics/threads OFF the main page!
Once a thread is OFF the main page, it is very difficult to find!
I can only imagine what new (visiting) readers think of all this.
Anyway, it seems to me there is not much interest in this topic/thread.
Best regards,
Les Banki
There seems to be a deliberate policy of re-churning 'exotic' topics in this forum.  At best it's merely a ploy to generate more traffic, but having just read someone petitioning Stephan to close a thread because sufficient proof of OU hasn't been forthcoming - jeez, if that's the case, every single thread would need to be closed! - it could also be something more sinister.
One question if I may, your intriguing tit-bit above regarding the 2000L of HHO per litre of water  - far far less water used than I would have thought - got me thinking again about cells under vacuum.  As you are pressurising the HHO anyway, would it be at all feasible to evacuate the gas from the cell with a vacuum pump, feeing the gas sucked out into your gas storage, while also increasing the rate of gas production due to the partial vacuum?
Les Banki
Quote from: Sprocket on April 17, 2011, 06:51:54 PM
‘Sprocket’ & ALL,
The “2000L of HHO per litre of water” figure is rather conservative.
It applies to electrolysis using DC current and the evolved gases are di-atomic. (H2 + O2)
If, and I say IF, a system can create ALL the gas in mono-atomic form, that figure would DOUBLE!
(And YES, it is possible, using RESONANCE.)
So, depending on the set-up, the real figure will be somewhere in between those figures!
About vacuum:
Personally, I have NOT tried this method but I know some experimenters have attempted it with dubious results.
But, over the years it all faded into obscurity, just like most other things in this  “free energy” chase!
For the set-up you are suggesting, you need to consider the practical side:
1.  Quality vacuum pumps are NOT cheap!
2.  Energy required by the pump.
3.  Extra (pressure) container is needed!
4.  How much (if any) increase in gas production can be gained?
5.  Is it worth the extra expense and complexity?
Perhaps I should have pointed out the OBVIOUS advantages of my set-up earlier but since you raised the vacuum issue, here they are:
1.  The electrolyzer CREATES its own pressure, automatically.  NO extra energy needed.
2.  The electrolyzer also serves as PRESSURE VESSEL and gas STORAGE TANK!
Best regards,
Les Banki
Plasmagorilla
Hey guys I have an affordable plasma ignition system listed on ebay. Just search gorilla plasma ignition on ebay. I am looking for hho motor builders to test my system. It is way more affordable than commercial overpriced systems from aquapulser ignition etc. I build them myself.  Here is a video...
http://www.youtube.com/awatch?v=peO1afaBX5E
Thanks guys.
Les Banki
Quote from: Plasmagorilla on May 08, 2011, 12:34:41 PM
Thanks guys.
No offense but your post indicates (at least to me) that you are NOT familiar with the characteristics of HHO gas.
One of the characteristics is that it requires only a VERY, VERY low energy spark to ignite/detonate!
Thus, HIGH energy sparks, particularly PLASMA sparks, are a HUGE over-kill and thus are completely un-necessary!
In other words, this is the wrong thread to promote your plasma  ignition system.
Best regards,
Les Banki
Plasmagorilla
Quote from: Les Banki on May 10, 2011, 12:17:41 AM
Best regards,
Les Banki
Thanks for your reply. Yes I do know that if the motor is running on pure HHO there is no need for any high energy plasma ignition, however there are those who are misting water or injecting water mist to supplement power and lower the amount of HHO required. For such motors high energy plasma ignition will be useful.
