Thanks to ALL for your help!!
Romero's experiments and OU principles
Started by plengo, June 10, 2011, 08:26:08 PM
romerouk
Quote from: energia9 on June 14, 2011, 06:33:28 PM
sadly i did not find any small holeless rod types,  anyway, I just saw a picture from Romerouk which had coils and iron powder inside, can you, Romerouk, confirm that your effect worked with iron powder, will you?
regardz
It works with almost any core type, depends on the magnets orientation.The best effect after mumetal I had with irondust cores. Ferrite is good too but only in NS systems.
I bought them from a UK company specialised in HIFI systems and speakers. They don't sell them separately but I hade some orders with other stuff before and they made me a favor.You can buy the inductors they sell with wire on them and redo them yourself according to your needs.Cost is about £9 each inductor plus the wire you will need for each coil.... quite expensive.These are 19 mm diam/38 mm long
energia9
Quote from: romerouk on June 14, 2011, 06:55:22 PM
simply, thank you
Magluvin
Quote from: lumen on June 14, 2011, 06:22:40 PM
Anyone know if Romero used some special wind on his coils other than the wire used?
I didn't see any capacitors directly on his coils but wasn't something said about this also?
He said i answered the question. Bifi capacitance. But he just wrote that you can add caps to you existing coils instead for the same effect. Thats why we didnt see the caps. the capacitance was in the bifi coil windings. ;]
Hmm I wonder how many of the oscillations make it to the cap. I would believe the first wave would be all that would make it, then the rest diminishing below cap voltage level.
But, maybe being in a resonant state from the git go, the first wave is beef. Saying if the freq of the rotor is in sync with getting the resonant oscillation started effectively, then that first wave can be very strong. The rest is just ringa ding ding. ;]
Me thinks. ;]
Mags
Mags
EMdevices
Peter made a discovery and I made a leap of thought over at the OUR forum.
start with this link and scroll down (or up)
http://www.overunityresearch.com/index.php?topic=862.msg14795#msg14795
ATTENTION !!!     ATTENTION !!!
This RomeroUK  dynamo COULD BE a MAGNETIC STORAGE FLYWHEEL!
RomeroUK,   can you confirm these speculations?   I'm not accusing you at all, I think you made a most important TECHNOLOGICAL DISCOVERY even if it might not be OVER UNITY !
redrichie
Romero,
can you explain the use of the stepped coils similar to Mullers in the last pic you showed.  I am only seeing single strand, so these coils are nothing special minus the step are they?  They have no coil wound on top coming halfway down for shorting, do they?
