Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
k4zep
Quote from: neptune on August 16, 2011, 02:59:21 PM
To those of you who may still be a little worried about pyramid angles and dimensions .Go to Youtube . Enter the following in the search box . Pyramid Magnet-free energy-english subtitle . Irrespective of the user name , the guy in the video is unmistakeably Thomas . In this video , he talks about the early V6 version .The date of posting is jun 2009 . Ignore any reference to the magnet , which he has subsequently said was a " security device " which operated a reed switch inside the reactor . Early on in this video he says and I quote .YOU SEE A PYRAMID MANUFACTURED OF METAL . THE ANGLE AND DIMENSION OF THE PYRAMID SEEMS TO PLAY NO BIG ROLE . So things may not be quite as critical as we had supposed . Another strange thing . He stops the fan by removing the magnet [thus opening the switch] When he replaces the magnet , the fan restarts . We are warned not to disconnect the fan in the v12 version . However , the v5 reactor was very different , and used a different sand conditioning method .
Hi Ken,
Is there any place I can go to see other versions of his reactors/etc.?
I would like to have a better overall view of the history of his work as
much can be learned from the past.
Respectfully,
Ben K4ZEP{
neptune
A strange thing I have learned about gypsum is that it is radioactive ! There are two types of gypsum , the naturally occurring type , and Phospho gypsum which is a by product of the fertiliser industry . Both types are , apparently radioactive , but the natural type is less so .I wonder if radioactivity plays some part in the working of the pyramid .It would be interesting to see what would happen if the amount of radioactivity inside the pyramid was increased , whilst not exceeding safe levels . One idea is to put a smoke alarm inside !
     On the German forum , Erdtaucher has been doing some interesting experiments . It is sometimes hard to understand all the details using auto translate ,but he seems to be saying that sometimes after filling and activating a reactor , it takes two to four days to show an output voltage .This is well worth noting . Another theory I had was that it might be possible to activate the reactor by connecting an AC or DC voltage at a lower , safer , level , whilst subjecting the reactor to vibration during filling .Just a theory .
     At least two members with complete pyramids have said that they can get the fan to run for a couple of seconds . For this to be meaningful , we need to know how this time period compares to a timed run-down test with the fan disconnected .
EnrgMizer
Hello all.  I am new to this site but not to "energy".  I have been looking to this concept for some time.  I have the access needed to materials, and machinery to go forth so to speak.  I have seen several interesting devices over the last several years (and have tested a few) and this "concept" is the only one that I can find that has a long history of the possibly being factual.
libra_spirit
http://www.resonantfractals.org/Magnetism/EarthNodes.htm
Here is how to locate the earth grid nodes, using a meter. The positive charged nodes, with negative all around them, will give a grid pattern of 16 and 32 foot centers, running east to west. They are the same points, that dowsers can feel, only the grids are sometimes bent by the presence of trees and such.
Copper of 13.5 cm length will make the hand go numb when held over these earth nodes, as it vibrates up.
http://www.resonantfractals.org/Levitation/QSR.htm
Here was my first attempt to see what this is all about.
I noted, with only the first inner coil, and the copper reactor, an overunity bump effect of DC charge, after pulsing between the coil and outer can quickly with an ohmeter. I believe I am seeing a conversion of a fast transition AC pulse to a long trailing DC potiential between the inner coil and the copper. Hard to believe!
The quartz sand poured in slowly with the CB transmitter on, is meeting a standing EM wave, and all sand tends to align into a coherent field, where vibration is converted into DC charge.
Now at the center of the pyramid line, the vibration running down the center tube, is a higher frequency then the outer tube, the sand in between recieves a torsion field gradient similiar to a Joe Cell. High frequency to the center, low frequency to the outside.
At this point it would seem the basics are all there. I have no intention of building a large pyramid, and have no room for such.
Dave L
namal
CAN ANYBODY HELP ME ON APPLYING HIGH VOLTAGE ON REACTOR? I HAVE SOME QUESTIONS
(1) SHOULD WE APPLY BOTH HIGH VOLTAGE AND HIGH FREQUENCY? OR ONE OF THEM?
(2) CAN ANYBODY SHOW ME THE DIAGRAM OF CONNECTING SWR AND OTHER EQUIPMENTS WITH THE COIL?
(3) ANY OTHER ALTERNATIVES EXISTS FOR APPLYING THIS VOLTAGE? INSTEAD OF SWR?
