Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
raburgeson
Can't use that example, you can apply Tesla's theory of oscillation to the wave in a pond. His mechanical oscillator could increase the size of the waves by adding timed pulses to them. If you add a timed pulse to a hertzian wave it will not change the amplitude.
Yes you are right like the action around a black hole. except it has no boundaries. It's acting that way throughout the entire universe all at once.
One wire can carry multiple energy transmissions. Now consider a 1 thousands of an inch cross section of the universe and how many transmissions it can carry. The problem is they are no coherent transmissions. The trick is collecting waves that are coherent out of the aether. waves with the same potential. As energy passes through the earth the minute resistance causes a  potential difference on opposite sides of the earth. That was what Tesla was going to prove to Einstein to prove him wrong when Einstein was a no show. Tesla went on a rant that the media had a lot of fun with. You'd have ranted too if you had spent your own money to prove something and the other party didn't show.
jbignes5
I wasn't referring to a hertzian wave actually. What I was referring to is the expanding ring of displaced Aether. They are very akin to regular fluidic waves. The potential increase from the peek of the circular wave is what I am talking about. This will not be like hertzian waves at all. These are one way pulses that actually collect free charges that fall all around us all the time. Even though they are minute there are a billion of them in a square centimeter and that is a conservative estimate. I believe that they are whats left of the conductors that have bigger charges that float up because they are more energetic. When these conductors loose the charges they fall back to earth. Some even collect and stick together and form rain when they loose enough charge.
raburgeson
Now start billions of waves in a pond each in a different place and watch them interact. One thing we have no proof of is are the waves bouncing at the edge of the universe, leaving the universe, or mobius looping. The sun produces a 28 day energy circle as it revolves. Of course the sun may not be a source of aether but, if it is there are a billion suns in billions of galaxies. Scientists have looked at everything from mild to wild and have no clue about the origin. Main stream they don't even like to admit aether existence.
I believe our senses are so limited and our technology is also, it will be thousands of years before aether is understood completely. In the bandwidths we are able to observe and the energies we understand we have observed there is something there. Being 3 dimensional creatures we are only getting a x,y,z snapshot of what's going on.
Even on a thin plane it would be unfair to assume that spots that look like they have the same potential do because the sum of the energies at that spot is a the sum of x number of wave energies. The amplitude might look the same but, the mixtures of transmission giving that sum may be far different.
jbignes5
I agree and I have said as much. But to tell you the truth who cares if the Aether is bouncing off the external. It is weather we can subdue this particle for our use without cause undue harm to us or nature. Thats the trick really.
Other have gone down this road already but we as a civilization was not interested in providing for our neighbors. We chose the I provide for myself or the me civilization. Now that it is falling apart we have to change our views. Of both our place in this world or even who we are really, both individuals and as a civilization.
I would think that most of us would love to not have to work and toil for our basic needs. Hey if you want to make extra then so be it but then we could have the luxury of doing such. Something must change or we will go extinct because we didn't want to share equally the bounties of this world provides on a basic level. Instead we rush and stake a claim to something we could not possible own and then charge others for partaking in that claim.
raburgeson
Tesla figured it out and you can too. Intuitiveness, inspiration and all the other things in any combination could get you there. Remember I said if you find what you need and there is an over abundance it becomes easy to share. Right now I'm reading everything I can on torsion field physics hoping I can fire 2 perpendicular torsion fields at a glass of water to see what happens.  Hope I get a little inspiration along the way.
Good luck with your project!
Frequencies help shake the water molecule apart. In case you think there is no plan and I'm just talking crap! We thought to try gluing in pedestal and iron ball to the center of a glass and surrounding the glass with ten electromagnets on 2 planes and using a solid state distributor to rotate the fields on each plane individually at different speeds. That's for a first try. We have other ideas on how this might be accomplished. Like Edison said, each failure shows you one more way not to do it.
