Time Travel Research
Started by telemachus, October 10, 2011, 03:51:51 AM
WilbyInebriated
Quote from: onthecuttingedge2005 on October 24, 2011, 01:44:12 AM
Wilby, I will let the world know, the day you stop stalking me is the day you will figure all things out. by then, all things will have come to pass.
not from your book but from my book. the book of science.
that's hilarious... especially coming from you, the mental midget who doesn't know the difference between "" and 0...   ::)
Quote from: WilbyInebriated on October 24, 2011, 01:48:00 AM
you mean Zilch, moron.
Zilch it is. 0
between you and I. you need to go on a diet, a diet of you and I. cause you are very unintelligible compared.
I follow all the current rules of science, you don't. that makes you a complete moron.
I do not make the rules, only the wickedly smart make the rules.
that you are not.
when it comes to """" and zero they are the same thing, I am a programmer and I know such things, in fact, I am an important programmer beyond this place.
I program A.I systems beyond your control.
WilbyInebriated
Quote from: onthecuttingedge2005 on October 24, 2011, 01:56:29 AM
Zilch it is. 0
that you are not.
no. i didn't mean "zilch". can you read what i wrote? check your eyes...take your meds...
you said, and i quote:
Quote from: onthecuttingedge2005 on October 15, 2011, 09:24:36 AM
If Ohm = "" Then Ohm = 0
If Ohm > 0 Then Ohm = Resistance
If Resistance = "" then Resistance = 0
If Resistance > 0 then Resistance = Heat
simple programming.
"" and 0 are not the same thing... ::) any novice programmer knows this... ::)
"" is a string. 0 is an integer. strings are NOT integers... tu stultus es.
"" is absence of information. 0 is a quantity...  again, tu stultus es.
you are no programmer, AI or otherwise. i doubt you could write a DOS batch file... ::)
Tito L. Oracion
void Zeroenergy(int will, int cut)
      return(mrn = will + cut) ;
; :D  :D  :D  :D  :D
;D not functioning function  ;D joke
CuriousChris
Quote from: WilbyInebriated on October 24, 2011, 02:33:26 AM
you said, and i quote:"" and 0 are not the same thing... ::) any novice programmer knows this... ::)
Not wanting to pick sides here, but as I am an accomplished programmer I feel I can contribute.
In many programming languages "" == 0 ( "==" means "is equal to?", "=" normally means assignment, as in let A be equal to B )
Some languages regard "" as undefined and will throw an error if you try to assign it to an integer or float. This is the common "NaN" error.
But languages such as c and its derivatives will normally assign the value 0 (zero)
QuoteIf Ohm = "" Then Ohm = 0
is entirely acceptable psuedocode and often used.
CC
