Ibpointless2 Crystal Cells
triffid
Well I had read that carbon nanotubes were found in soot.Soot is at the least amorphous carbon and I can apply it to electrodes in my kitchen.If you make a carbon arc with pencil lead you should get some carbon nanotubes(less than 30%).  Its turning out that soot (  amorphous carbon) is ok .Its conductive and may be a way to protect my magnesium strips in the future.As of late last night after the electrode had cooled some I got a max of .25 volts.triffid
triffid
Murfedit,here is a pdf file on making carbon nanotubes from mustard oil soot and includes electron microscope studies
http://www.ias.ac.in/pramana/v65/p681/fulltext.pdf  triffid
triffid
The mustard oil used in the experiment was procured from a local market and
of edible quality. Normally vegetable oils contain glycerides of a mixture of sev-
eral types of fatty acids. Mustard oil is comprised of 76% monosaturated, 23%
polyunstaturated and 1% saturated fatty acids like oleic, linoleic, linolenic acids
(all 18-carbon chain with unsaturation) and arachidic acid (20-carbon chain, satu-
rated). Burning of other edible oils do produce soot of interesting properties (under
investigation), but mustard oil was selected ¯rst because it contained very high un-
saturated fatty acids among all the available, commonly used edible oils, and for
its low cost. The raw soot was collected by burning mustard oil with the aid of a
cotton piece in insu±cient air
So one could soak a cotton ball in pretty much any cooking oil.lit it on fire,drop it in a jar and close the lid
to get soot.
triffid
My strip of magnesium metal with soot on it is still producing voltage. Where the layer of soot is thickest,I get the strongest voltage readings.I can get .59 volts where the carbon layer is thickest.Where I got .6 volts yesterday (before the strip cooled down) And where its thinner I can now get .15 volts.There is a bead of carbon on the backside of the strip and thats where I get .59 volts today.triffid
triffid
There is no water in this reaction.Except for water in the air.I have a battery from a single strip of metal!I tried putting soot on copper(no voltage was observed).Black copper oxide is not conductive.So that may have been the problem?triffid
