Thanks to ALL for your help!!
Accelerating motor-generator selfcharging capacitors without any batteries
Started by hartiberlin, January 24, 2012, 04:55:13 PM
Arrow
1 small step forward for us with  honourable PMMG4HYBRID
Solenoid Driven Repulsion Motor
http://www.youtube.com/watch?v=ie7iHqMVkuc
testbed on old HDD:)
Dear PMMG4HYBRID THANK YOU VERY MUCH FOR SUPPORT!
We are starting this simple motor model construction!Soon you will see OU on it!
Easy and cheap, grate "toy"!
Truly
Rob
Read 8154 times
Arrow
We (Armenian team) have got new setup, its better one based to our tests and observation, use it free guys.
soon we will finish our HHD micro pulse rotor completely, working on the micro solenoid efficiency.Trying to drive it and energize from HDD 3-phase
http://www.sendspace.com/file/0m898x
scaled to 1:1 drawing to print at A4  http://www.sendspace.com/file/elkcj4 (PDF)
don't try to scale it to bigger one - it will not work!Otherwise you need to find new setup with diff. magnets.Just leave spiral and work on it at new scale.
We almost sure it can support other types of magnets(not tested) - ,just keep logic.
We are very happy that can help community with our new research works to get this fast running new setup "toy"
Thanks to honourable Mr. PMMG4HYBRID for fresh idea for us & probably for all of us!!!
Truly
Rob
Read 9114 times
Arrow
We focused and stop on this construction of actuators with built in magnets.
For such pulse rotor we will make such actuator from 10x2mm Neo tablet
Going to feed it with 100mv 100ma and see what force in Kg we can get from such small amount of power
concept drawing http://www.sendspace.com/file/mzak6k
Truly
Rob
Read 9339 times
Arrow
Our works in progress, actuator developed at cad.
We just want to show its internal parts and motion logic. It is the most efficient part.We refused to use general solenoids as far they do not have relevant speed of acting and not efficient. Our baby pulse rotor at HDD going to turn as fast as it is possible.
Next info will come after results. Tomorrow good day to start fabrication works at my lab - we are going to see  this baby girl full power to get OU:)
http://www.sendspace.com/file/brz6n9
Truly
Rob
Armenia Team
Read 9482 times
Arrow
We made test of HDD RPMs and get bad results, HDD can not support even such small pulse rotor actuator power.HDD need high RPMs to reach relevant power output to support actuator needs.
http://s7.postimage.org/6ny96d96j/hdd_A_rpm_dep_549ma_3630rpm.jpg
http://s13.postimage.org/fxdaiw3sn/hdd_v_rpm_dep_4390mv_5070rpm.jpg
Bad result also results.We will start up actuator from batt, count the output at RPM's and then will make relevant multi pole magnetic small genset.
Furthermore, such actuator able to support 2 pulse rotors and we are going to use such benefit that can give as possibility to use 1 fast small diameter turning pulse rotor-genset to support both rotors running timing only for 1 actuator power dl cap charging  and next, slow running and powerful big diameter pulse rotor and its diff.genset to charge LiPO batts in such need,
Hope we will get result with 1 to 7 actuator gear reduction (7 routines actuator dl cap charging rotor and 1 routine for main genset rotor to chardge external and disconected from system feed batt to reach OU)
Moreover bidirectional actiator can supports its own relevant small BEMF, remember? shaking torch light construction? So its otside magnet on shaft will move magnet that will add energy to its DL CAP's.Actuallly we want to develop smart system that can "see" load of main rotor to drive it fasteer when load going up and slower - when load at main rotor going down. I dont know how it is in English sorry in Russian its is ОбраÑ,ная оÑ,рицаÑ,ельна и положиÑ,ельна связь.Such system will be able to drive main rotor at max stable RPMs with and without load on the end.
And in the end - system will support the crash of small magnet rotor magnets by its main rotor batt power that will be conected automaticalli to the brushless small PWM motor to run small rotor. At such crash system will switch on alarm to call "personel" to change small magnet heart to new one:) etc.....
In one word it is Tirer-4 Redundancy 2N+1.System have only 1 narrow bottleneck point - main bidirectional actuator mechanics that will beating very fast
We will see what we can squeeze form such system.We don't know if such binary pulse rotor +actuator systems concept already alive....We think - Only steam engine close more or less to this explaned concept with its 2 diff. sise pistons - yes/no?
We like such system Redundancy:)
Unic magnet-electrical  actuator fabication works at full progress.
And again grate thx to honourable Mr.PMMG4HYBRID for such perfect idea to us about single pulse rotor!
New Idea came to us from human nature - human has heart and it is beating fast to move big heavy body based on 1 general brain named here as actuator!
Truly
Rob
Armenia team
Read 9871 times
