Accelerating motor-generator selfcharging capacitors without any batteries
Started by hartiberlin, January 24, 2012, 04:55:13 PM
Arrow
Our last test with our rotor - top magnet 2 pole cylinder
http://www.youtube.com/watch?v=GQReVEs8zAs
Truly
Rob
Armenia team
Read 11195 times
Arrow
Some job progress at the process of actuator piston creation.Part become hot, need to cool down, coffee time:)
http://www.youtube.com/watch?v=4oI9chNm00Y
1/2 of piston ready to go under the dividing head to get magnets buried regions and piston chamber air compensating injectors holes, otherwise it will get real air compression that's able to create friction and relevant acting speed will be shuts down to unknown.
Here is the video what I mean, this is wrong behavior of actuator piston, there is air compression on chamber  > http://www.youtube.com/watch?v=M4uWmBuaUDU
ready part here, further works on progress
http://s58.radikal.ru/i160/1202/9a/50b0f436623f.jpg
http://s40.radikal.ru/i089/1202/04/1169283e4db8.jpg
Truly
Rob
Armenia team
Read 11365 times
Read 11413 times
billaynes
What about a 10000 year old Minoan magnet motor, that supposedly is not what it’s supposed to be?
http://www.explorecrete.com/archaeology/Malia-Palace/07_Malia_kernos_EN.html
There are also some ruins of the same… oytside the temple of Hephaestus in Athens Greece and some strange… vessels nearby there, such as these.
http://www.world-mysteries.com/sar_11.htm
What do you think?
Arrow
Historical numerous proves that aliens had visit Earth and had war between its atlants race to get gold from our planet to save temporally their collapsing planet form heat of local star(SUN) Ha:) and our Grand Grand N times Pa's call them God's :) That is why I wish to e2matrix - God bless You FOREVER!!!
Nothing else :) Dear billaynes this is tech forum you are kindly asked to be more specific, please!.We are trying to recall all our hi tech knowledge here that was lost in centuries to survive and live in peace. Can you help us?
For good bats that can be reachared by open fire I can recommend you 1878y invention of German guy It is produsing 0.78volts 1 cellCurrent depends to Cu surface, as much as it is big that much high current.
Components:
Glass or ceramic small cup
NaOH - 1.29
Cu
Zn
By heating on the open fire the Cu plates by it Oxide when cool down
Cu Oxide creates power with Zn in NaOH
Recharge Cu on fire and plate it with new portion of Oxide and it will generate power again until cupper will not vanish in fire:)
I have done it when Armenia had tuff energetic crisis from 1992-1996, We had only 1 hour per day the AC power and very pure one by its quality.
I swear to my self to fight as warrior with tuff knowledge base against of such situations at all my life until will not get solution! Now I am the way and nothing will be able to disconnect my systems thats provides the power and heat to my people and nation!
Truly
Rob
Armenia team
Read 11937 times
e2matrix
Arrow,  Thanks for the comments and blessings :)   Based on one statement in your message above I would like to clarify one or two things.  I may have misunderstood what your were saying but it sounded like you think the spiral shaped pieces are magnetic.  Since these blueprints and the associated douments are not mine I may be wrong but I understood the documents to say that the flat spiral shaped cutouts were iron or steel.  The author of the doucment said: " be sure not to use magnetic metals besides the iron spiral plates so it won’t interfere with the magnetic pull."  So I am fairly sure his meaning is that you do NOT want any metal or iron in holding things together or near the magnets (nothing that would be attracted by a magnet) since that would throw off the attraction of the spiral plates to the magnets.  To clarify his statement said 'besides' when actually it should have said 'beside' or near.  His statement was slightly misleading in that in the strict English interpretation you might think that nothing should be magnetic except the spiral plates BUT I am sure that would be wrong to interpret it that way.  So if you did think the spiral plates need to be magnets this would wrong.  The only magnets in this project are flat bar magnets in the middle of the unit.  Even though the document and blueprints were made by someone in America that is English speaking (as I recall from some other discussion) there are many little nuances and ways to misinterpret things written in English and sometimes just the addition of a single letter like 's' can change the whole meaning or leave it open to several interpretations.  Other languages like German tend to be more precise and leave much less to the readers interpretation.  Anyway I just wanted to make sure you didn't spend a lot of money on spiral magnets as I am quite sure that is not needed.  I am sure it is simply the attraction of the magnets to iron that does the work in this motor.   Best of luck with your project!
