Accelerating motor-generator selfcharging capacitors without any batteries
Started by hartiberlin, January 24, 2012, 04:55:13 PM
Arrow
Quote from: e2matrix on February 26, 2012, 06:47:57 PM
Best of luck with your project!
Thanks again, we will try both combinations because in the topic about V-gate drum rotor ( Roberto 33, if you know this story) one of good engineers from US had try ferrite insted of magnets on V-shape  and got negative result.I had personal contact with man and I am  100% sure in this info!
The most important key in drawing is shift angle between the spiral gaps! That's the gold point of construction, why? Have you seen the video with 4 line dram rotor that is spinning?  http://www.youtube.com/watch?v=pY-QZFm3sZc we had try it, it was 22degree shift between the 3angle magnet lines  and both sides was magnets. We have got result but low energy, now new drawing telling us new angle 32 degree shift and its seem to be true because there are 11 lines !Math model telling us - more power there is.Probably it is coming from 11 lines, we don't know, we will see... BTW your comment about restriction of using in rotor metal bolts etc is absolute true!
We are very close to know true construction because of you dear e2matrix! We Bless you again and again!Thanks!We wish you long productive life, happines, sun, blue sky and strong health at all your life!
Sorry for my English
Truly
Rob
e2matrix
Thanks again Rob.   Blessings to you and your team too!  Glad the document I shared lead you to that angle which I hope is the magic angle. I understand now about the 11 lines and the 32.72 degree angle.  11 x 32.72 = full circle or ~ 360 degrees.  I think it is interesting the author of that document found that 1/11 th of a circle to be the best angle to use.  I think there is magic in the number 11 ;)   I look forward to hearing of your successes.
Arrow
Quote from: e2matrix on February 26, 2012, 09:24:16 PM
Until we will not finish first pulse actuator type magnet rotor  we will not switch to new one.As many magnet rotor options that can function with pretty good OU that will be better for everyone:)
High Performance Bidirectional Actuator piston (HPBAp) after dividing head drilling is here http://s017.radikal.ru/i437/1202/1f/8c4c996dbc87.jpg
BTW, Here is one of mine desk books about theoretical electro-chemistry http://www.sendspace.com/file/6j4fht it is on Russian, sorry:(
We have here many Armenians from former Soviet who are living in US and Europe, so they can use it in need.Hope they did not forgot language.
Truly,
Rob
Armenia team
Read 12411 times
Arrow
We have got interesting results about Neo magnet energy, see attached
http://s003.radikal.ru/i203/1203/45/ca697a2e0a09.gif
Neo magnets H43 can hold 342000Joule/m^3 energy.
So, this is H43 magnets max energy  as input.
You can calculate your magnets volume on cubic meters and compare 342000Joule to yours Neo magnets volume results.
We don't have English language base calculation, only Russian, sorry.
We can share here Russian type. Is that OK?
Truly
Rob
Armenia Team
Read 13403 times
gyulasun
Hi Rob,
Yes I think it is better to see it in Russian than not seeing it at all,  especially if its text is not in a picture file but in a pdf or doc or txt file to be able to use translator software.   ;)
Thanks for you and your team for all the efforts so far.
Greetings,  Gyula
Quote from: Arrow on March 02, 2012, 05:48:50 AM
So, this is magnets max energy input.
Truly
Rob
Armenia Team
Read 13403 times
